Hole to be too narrow for the bar to fit through properly.
Huguesny
(@huguesny)
Hello,  It seems to me that the hole itself has a problem; it appears to be too narrow for the bar to fit through properly.
https://ibb.co/s94NV7p9
Do you have an idea how to process ?
Postato : 01/06/2026 1:44 am
vhubbard
(@vhubbard)
RE: Hole to be too narrow for the bar to fit through properly.
Make sure it is the correct bar size.   Make sure there is not a bur or ridge stopping the bar.   Then make shure the clamp screws are loose.   Use a screwdriver in the slot to open the clamp a little and get the bar in.   It shouldn't take much.
Postato : 01/06/2026 1:07 pm
Huguesny
(@huguesny)
thanks, it worked !
Postato : 01/06/2026 1:41 pm
Huguesny
(@huguesny)
Another question: is it normal for the Y-rod to have a gap on one side but not on the other?
https://share.icloud.com/photos/01b899gGC2dhqhy27O79DppmQ
Postato : 01/06/2026 8:16 pm
