First use and fail
quarkholon
(@quarkholon)
First use and fail
Core One +
First day, after calibration, the wire systematically gets out after idler, never redirects to the nozzle.
I add pics and video.
Any customer support or service possible ?
Many thanks
Veröffentlicht : 15/01/2026 8:38 pm
RE: First use and fail
It's hard to tell but from the first photo it looks like the nozzle isn't fully inserted into the heatsink assembly.
Veröffentlicht : 15/01/2026 11:13 pm
quarkholon
(@quarkholon)
Thank you.
Amocher pic.
I ordered it full mounted, first self test worked straightforward and now it's stuck.
Unmounting/mounting the devices and parts as I am a beginner is quite hazardous.
Which options do I have ?
Veröffentlicht : 16/01/2026 7:08 am
miroslav.h4
(@miroslav-h4)
The first option is to get rid of the filament. The second option is to download the CORE One assembly manual and see how the block assembly in the cooler should look correctly. This last photo is completely useless! We've already seen the filament that has come out! I want to see a photo of the heating block from the front so that the partition in front doesn't get in the way. At first glance, it looks like the nozzle and heating block assembly in the cooler is incorrectly seated.
Veröffentlicht : 16/01/2026 1:33 pm
Steve
(@steve-5)
Even without a different photo it is clear that the nozzle is not properly seated.  The top of the heat block is nearly level with the part cooling duct!
@quarkholon, follow the instructions here to properly insert and secure the nozzle assembly.  Be careful to not pull the assembly any lower as you are already at risk of damaging the nozzle heater and thermistor wires!
Regards,
Steve
Veröffentlicht : 16/01/2026 2:51 pm
I can see now from the latest photo that the nozzle is not fully inserted. The heat block should not extend below the fan shroud. Loosen the thumb screws and push it all the way up. Only around 1mm of copper on the heat break tube should be visible.
quarkholon
(@quarkholon)
Thanks. I am in the middle of investigations with PRUSA CC.
Brand new Assembled Core One + received 2 days ago, self test went ok and then all screwed 🙁
idler checking
nozzle well in place (pushed up)
acupunture needles
reran the calibration testing
As if the nozzle was screwed
Veröffentlicht : 16/01/2026 3:19 pm
quarkholon
(@quarkholon)
Fixed with cautious loading:unloiading filament and purge with acupuncture needle.
Context : PLA material
Now aware of mounting/unmounting nozzle and cleaning the idler 😉
Works for now.
Veröffentlicht : 19/01/2026 7:09 am
