First prints - Under extrusion? / Look of the presliced models
Thomas D.
(@thomas-d-2)
Hello everyone,
after I completed the assembly of my Core One yesterday, my first print don't come out as expected.
These are made from the presliced models (key-chain + 15 min benchy):
This looks like heavy under extrusion to me. Shouldn't the pre-sliced models look much better? The calibration of the gearbox had been completed successfully. Filament is Ender PLA+ (190-230°C).
This is a XYZ test cube silced on my own on default settings (0.4mm CHT Nozzle, Generic PLA 205°C). The cube also shows signs of holes:
How do these presliced models have to look like? What can I do against the under-extrusion?
Ce sujet a été modifié il y a 10 months par Thomas D.
Publié : 20/07/2025 10:47 am
manu1482
(@manu1482)
Membre
RE: First prints - Under extrusion? / Look of the presliced models
Posted by: @thomas-d-2
Hello everyone,
Conseguiste solucionarlo? Yo tengo el mismo problema
Publié : 15/09/2025 4:39 pm
Hermann
(@hermann-2)
It looks as if the belt tension is too low and the XY axes are oscillating.
Publié : 16/09/2025 10:04 am
Tim
 Tim
(@tim-21)
Membre
Does the extruder make any noise while printing? Clicking or raspy noises?  Also, verify the preferred print temps for the PLA you are using. If it is a higher temp PLA, the provided bgcode files may not be using a high enough temps for your specific PLA+ ... you might instead try printing with the Prusament filament that comes with the kit. If that filament also gives you that same print quality, post photos of that result.
I saw similar on my Core One when I first printed my own sliced models, and today think I used a print profile for my older Mk3 -- not compatible with the Core One.
In later prints, I was able to get better print quality out of the C1; but have yet to equal the quality of my Mk3 ... I guess speed has a price.
And I second the opinion your belt tension is suspect based on the unshapely U in the keychain logo.
Publié : 18/09/2025 3:27 am
