Filament no longer feeds after first print
I purchased a fully assembled Core One and after the first print, I noticed that the filament would not feed pass the gears down through the hole to the hot end. I made sure that I cut the end of the filament as instructed but it gets caught. It is if there is a sight misalignment in the path of the filament with the hole where the filament enters the hot end. Maybe if the had a slight bevel (funnel -like) entry to the hot end would help. Can someone help suggest what I should do next to resolve this issue?Thank you in advance. Victor
RE: Filament no longer feeds after first print
If you are printing PLA, it's possible you got a nozzle clog. Try doing a cold pull. There is a wizard for that on the UI screen. I'm not in front of my printer but I believe it's in the Calibration section.
Thank you hyiger for the suggestion. I checked this and the nozzle is not clogged and is clear. I looked at this several problem several times and what is happening is that the filament catches on side of the hole just before it enters the hotted so it I get the clicking noise since the filament stops feeding. There seems to be a very slight misalignment of the filament feed path with there hole just before it feeds into the hole that leads to the hot end. I tried adjusting the tension screws but it doesn't seem to help. I also cut the filament at angle as recommended but it still doesn't help. Any suggestions would be greatly appreciated so that I can get my Core One working again and not have to continue to use my Mark 3s. Can someone in Prusa Technical support help? Thank you Victor
Contact Prusa Support via chat - you will need your serial mumber.
I will contact Customer Support via chat when I return from my trip to Italy in the first week of April regarding my problems with my Core One. Thank you, Victor
