Failed Y-calibration of a new CoreOne
Stránka 22 / 22
Korebreach
(@korebreach-2)
RE: Failed Y-calibration of a new CoreOne
I found this post after failing the initial Y-Axis calibration.  I re-did the belt tension.  I gave some "persuasion" to the bar that the extruder sits on (as the instructions are now saying).  I looked at gaps and did everything I could think of.  Then... out of chance... I happened to notice that the filament sensor cable was protruding away from the right wall a bit.  I pulled the slack on that to the rear (straightening the cable).  No more failed calibration.
Napsal : 09/05/2026 3:42 pm
1 lidem se líbí
Posted by: @korebreach-2
Yes, besides a bent gantry probably the second most common is the filament sensor cable interfering with the y-axis movement.
Napsal : 09/05/2026 3:47 pm
Yes, that's a classic trap which has been mentioned here quite often. I like to think that I was the first to fall for it. 😉
Napsal : 09/05/2026 3:54 pm
mbiasotti
(@mbiasotti)
Yeah - good observation. I did the kit build of my Core One and had the same issue early on  - Y axis gantry interference with the filament sensor cable.
Napsal : 09/05/2026 4:29 pm
Stránka 22 / 22
