Failed Y-calibration of a new CoreOne
Pagina 21 / 21
RE: Failed Y-calibration of a new CoreOne
@butters, I see that you have been active and posted in a couple of other threads in the meantime. It would be good if you kept the dialog going in this thread as well: Do you understand the belt routing change you need to make? Do you need additional help, or have you already done it (with which result)?
By the way, the incorrect routing through that right-hand idler block also explains why your belts were too loose after you had reattached them. By not going around the idler as it should, the belt is taking a shortcut which makes it a couple of cm too long. By routing it correctly, and then fastening it to the Nextruder back plate as shown here, you should be back in business.
Postato : 20/11/2025 10:39 am
Butters
(@butters)
The belt is correct, it's possible the picture which I posted was not clear. When you look at this picture; https://help.prusa3d.com/guide/5-corexy-assembly_835522#845973 the Y-axis goes around the front pulley, then the teeth must go around the pulley in the linear assembly.
Posted by: @jurgen-7
Postato : 20/11/2025 11:51 pm
Posted by: @butters
@butters, it's not correct you have the belt routed on the wrong side of the pulley.
It should look like this photo. Pay close attention to the image in the circle:
Postato : 21/11/2025 12:42 am
See how the belt is oriented on my printer? The teeth of the belt go around the pulley like this:
Postato : 21/11/2025 12:58 am
Butters
(@butters)
That is the exact same as mine. There is no other way, that would make it work. You can't have the teeth from the belt the opposite direction.
Posted by: @hyiger
Postato : 21/11/2025 1:19 am
Posted by: @butters
Could you take a photo from the same angle then to confirm? With the image you attached earlier it looks exactly like you don't have the belt around the pulley in the correct way.
Postato : 21/11/2025 1:30 am
1 persone hanno apprezzato
I tried to take an image from a similar angle. You can see the difference. The belt should be parallel to the other belt and the frame whereas yours goes off at a sharp angle
Postato : 21/11/2025 2:09 am
From the top image you provided you can also see that the belt is not parallel to itself which is wrong
Postato : 21/11/2025 2:16 am
Posted by: @butters
You still have not understood where the problem is:  Yes, the orientation of the belt (which side the teeth are on) is correct. But the position of the belt is incorrect.
Please push the print head in your printer to the center position (above the center of the heatbed). Look into the printer from the front, i.e. through the open door. Look at the idler block on the right end of the gantry. Compare what you see to the photo below.
In the photo below, the belt comes out on the right side of the pulley. In your printer, the belt comes out on the left side of the pulley. That's the problem.
Postato : 21/11/2025 6:44 am
Raaz
 Raaz
(@raaz-2)
Didn't it make a horrible noise, while running the Y-calibration or moving the Nextruder manually?
The teeth are rubbing on the PC-CF part and might even show some damage or some debris might lay around in the corner and on the heatbed..
Postato : 21/11/2025 7:41 pm
@butters, a week has gone by -- did you get your belt routing and XY calibration fixed? I see you have been back on the forum in the meantime. It would be polite to give us an update, either confirming that this has been resolved or asking any follow-up questions you might have.
Postato : 28/11/2025 11:20 am
Butters
(@butters)
I have completed and fixed the Y-axis calibration and it passes. Although, now the HOMING test is failing, I tried loosing and maximum tightening the tension but the calibration continues to fail.
Postato : 29/11/2025 4:25 pm
Butters
(@butters)
What does the CoreOne do to belts, I had one passed Y-axis test and HOMING test, then it's as if the belt comes loose and I can't even do print. I'm fighting with this quite alot; I'm now going on over a week. I'm taken apart the nextruder numerous times.
Postato : 29/11/2025 11:05 pm
Mac-N4MCC
(@mac-n4mcc)
Could you post photos of the sides of your middle pulleys on the gantry. I had a similar problem.
Extra HAM (and eggs some say) Radio - N4MCC
Postato : 10/01/2026 11:29 pm
Mac-N4MCC
(@mac-n4mcc)
https://forum.prusa3d.com/forum/prusa-core-one-general-discussion-announcements-and-releases/core-one-owners-regretting-their-purchase/paged/5/#post-775761
Check the long discussion in this thread on Y-axis issues.
Postato : 10/01/2026 11:36 pm
Posted by: @mac-n4mcc
Wasting time replying to Butters. We won’t see him until the next problem pops up
Postato : 11/01/2026 12:54 am
Posted by: @galaxy-princess
I'm away from my printer for a week or 2. will post when I get back to it.
Interesting post from a first-time poster. Is this just meant to turn into spam "when you get back to it"? 🤔
Postato : 12/01/2026 3:18 pm
Yes, this is indeed odd.
Postato : 12/01/2026 4:04 pm
DaveB
(@daveb-2)
Utenti
RE: Failed Y-calibration of a new CoreOne a new potential fix
CORE XY belts
I had continuing Y Axis Calibration failures & tried belt tensioning & bending the brackets multiple times with no success. I eventually found that I had assembled the belt pulleys incorrectly (Duh!) & no amount of tensioning or bending would solve it. It is possible to assemble the unit with the belt pulleys reversed left to right (black arrows in the pic) this causes the belts to follow the path shown by the yellow lines. If like me you have done this, then the mysterious Y-Axis calibration failure immediately disappears & you are up & printing. These pulley mounts are held in place by 3 screws, but the 'bendable" corner brackets have 4 holes which enables it them to easily be assembled the wrong way around. Prusa could easily fix this by making the corner brackets "handed".  Hope this helps.
Postato : 16/01/2026 6:11 pm
miroslav.h4
(@miroslav-h4)
Unfortunately, if someone doesn't have eyes and can't see how the belts are guided over the pulleys in the picture, then unfortunately there's no help for them. But in my opinion, 80% of them are builders who would like to have the printer assembled "in a hurry" and then it turns out like this. Prusa doesn't have to solve anything, the builder just needs to carefully follow the assembly instructions. In my opinion, the instructions are written in such a way that even a trained monkey could assemble the printer according to them, if they could read.
Postato : 16/01/2026 9:11 pm
Pagina 21 / 21
