Exrtuder fails to load filament. MMU3
I finally figured out there was a small filament portion blocking my finda pathway, and then came to the next issue.. When I go to load a filament, it gets to the extruder and then backs out. I've taken the cover and gears out, double checked for blockage, and removed the nozzle as well. The same issue occurs and the sound can be heard in the attached clip. What am I missing that could be causing the issue?
For the sake of it, it's not the tip of the filament. Else it wouldn't have made it through the MMU3 unit.
I've followed directions here: Error-04108 with no luck.
Thanks
Posted : 26/01/2026 1:53 am
