[Risolto] Door Tape
pjs37
(@pjs37)
Door Tape
Any recommendations for the door tape?  Following their instructions the tape still stuck to the door before it even rotated and its all jacked up now.  Anyone have a recommendation for a replacement tape that is similar thickness?
Best Answer by Chris Hill:
It's easy to mess this up - mine grabbed in the wrong position at the bottom while I was paying attention to the alignment at the top.  And you only get one go.
I had some of this to hand, which seems to be very similar to the original tape, so it was an easy fix - it just needed cutting to the same size, using the strips of backing tape from the originals as a guide.  The worst part was cleaning the remains of the original tape off the inside of the handle.
Postato : 30/04/2025 3:58 am
Chris Hill
(@chris-hill)
RE: Door Tape
Postato : 30/04/2025 9:31 am
pjs37
(@pjs37)
RE: Door Tape
Worked perfect thanks!  Trying to get through all my punch out issues now lol
Postato : 30/04/2025 10:44 am
Kyosuke_14
(@kyosuke_14)
RE: Door Tape
Just use two screws and nuts, there is holes for that and it hold great.
