Core One Shadow Printing
Filip
(@filip-5)
Halfway through a test print (the benchy boat), the printer stops using the filament and starts some sortnpf shadow printing dance. See movie.Shadow Printing
Opublikowany : 19/02/2026 3:18 pm
chmax
(@chmax)
RE: Core One Shadow Printing
the shadow dance (nice description 🙂 ) is the printer that keeps printing without noticing that it is just printing air.
I would start with making sure that the filament is not tangled on the spool (preventing it to roll in). Then check the tension on the idler screws of the extruder: if they are too open, the filament will not be grabbed properly and could slip (not being pulled by the teeth in the extruder). See the building intructions for the proper tension (if I remember correctly they should align with the border of the extruder). A possible final check is if the right material was selected as being loaded...
Opublikowany : 20/02/2026 11:14 am
1 ludzie polubili
Filip
(@filip-5)
Thanks for this, I’ll have a look at the idler screws 👍
Opublikowany : 20/02/2026 12:38 pm
