Core One + First print fails
jsb
 jsb
(@jsb)
I just finished my first prints even though the printer won't pass the homing test. The keychain failed about 70% of the way through. Could that be due to unsatisfactory homing? Have tried to troubleshoot with no luck. Now printing benchy and the whole room is shaking. Printer is sitting on a sturdy wooden table. Print is failing, layers are not in vertical alignment. Can anyone help?
Respondido : 12/12/2025 11:31 pm
1 les gusta
RE: Core One + First print fails
So far you have given us very little information to work with.
  • I assume you have built the printer from a kit?
  • In which way does it fail the homing test?
  • Did you complete the gantry alignment and belt tensioning? Best done with the new firmware 6.4.0 and following Prusa's updated guide.
Respondido : 13/12/2025 6:41 am
NickAtNight
(@nickatnight)
Well, we need to get that printer to pass the homing test !
- Okay, you were printing the 'keychain'... Is that the Original PRUSA demo print?
- Benchy is causing the 'whole room is shaking'.
       Not sure how sturdy your table is.
         CAN YOU PUT THE PRINTER ON A MORE STABLE SURFACE (temporarily).
         LIKE A CONCRETE FLOOR ON THE GROUND.
            that should eliminate the shaking causing the printing issues.
Respondido : 13/12/2025 6:44 am
NickAtNight
(@nickatnight)
ChatGPT response to your post...  (Be careful, ChatGPT is known to lie !)
Hello, thank you for contacting Prusa Support 👋 I’m sorry to hear about the trouble with your Core One, but we’ll get this sorted step by step.
Based on your description, there are two critical issues happening, and they are directly related:
1️⃣ Printer does not pass homing – this must be resolved first
A Core One that cannot complete homing correctly should not be printing. Yes — unsatisfactory homing absolutely can cause mid-print failures, layer shifts, and severe vibration.
If homing is unreliable:
The printer does not know its true position
Motor corrections accumulate
This leads to layer misalignment, shaking, and eventually print failure
This explains:
Keychain failing ~70% through
Benchy layers not stacking vertically
Whole room shaking (this is not normal behavior)
2️⃣ Excessive vibration and layer shifts
The Core One is normally very stable, even at higher speeds. If the room is shaking, something is mechanically or electronically wrong.
Typical causes:
Missed motor steps
Loose belts or pulleys
Axis binding
Incorrect motor current or skipped homing detection
🔍 Let’s troubleshoot in the correct order
Please go through these in sequence and do not print until homing is fully resolved.
✅ Step 1: Describe the homing failure precisely
Please confirm:
Which axis fails homing? (X, Y, Z, or multiple)
Does homing:
Stop with an error?
Complete but sound rough?
Retry repeatedly?
Succeed sometimes and fail others?
Also tell us:
Does the printer display any error or warning tone during homing?
🔧 Step 2: Mechanical checks (very important) A. Belts
Check X and Y belts:
Firm, not loose
Not overtightened
Pluck test: belts should produce a low, consistent tone, not floppy or extremely tight
B. Pulleys
Check all motor pulleys:
Grub screws tight
One grub screw must be tightened against the flat of the motor shaft
A loose pulley can cause:
Layer shifts
Violent shaking
Failed homing
⚠️ This is one of the most common causes of your symptoms.
🧭 Step 3: Axis movement test (printer OFF)
Power the printer OFF
Manually move:
X and Y axes
Motion should be:
Smooth
Even resistance
No grinding, binding, or catching
If you feel resistance → stop and report where it occurs.
🧪 Step 4: Sensor and wiring check
Verify all endstop / sensor connectors are:
Fully seated
Correct orientation
Check that no cables are:
Pinched
Pulled tight
Rubbing on moving parts
A partially seated connector can cause intermittent homing failures.
⚙️ Step 5: Firmware & calibration
Confirm you are running the latest Core One firmware
Once homing works 100% reliably, perform:
Full Self-Test
XYZ calibration
First Layer Calibration
Do not skip any of these steps.
🚫 Important safety note
Please stop the current Benchy print immediately.
Continuing to print while the printer:
Fails homing
Shakes excessively
Shifts layers
can lead to:
Motor damage
Pulley wear
Belt damage
Print head crashes
📌 Summary
✔ Yes, failed homing can absolutely cause your print failures ❌ A Core One should never shake the room 🔧 This is almost certainly a mechanical or homing-related issue, not slicer settings or the table
Next reply — please include:
Any on-screen errors or tones
Whether any pulleys or belts felt loose
Whether axis movement feels smooth with power off
We’ll continue from there and get your Core One printing correctly 👍
Respondido : 13/12/2025 6:46 am
Please, let's not post ChatGPT advice here, especially such long texts. It does not help the signal/noise ratio, and everyone can ask ChatGPT directly if they expect that to be helpful.
In the specific post above, ChatGPT's advice is not incorrect. But it suggests some steps which are pretty intrusive and should not be the first thing to check. (Who wants to take out the motors to check the grub screws?) And it is very hazy on things where much more specific advice is easily available. ("Belts should produce a low, consistent tone" -- I already posted the link to the belt tensioning guide which explains in detail how to set them correctly.)
Respondido : 13/12/2025 8:38 am
1 les gusta
hämppis
(@hamppis)
Miembro
A few weeks ago, my Core One printer started having problems starting to print when I switched from PLA to PETG, taking 5 minutes to return to its home position, etc., and always ending in a "collision" The objects printed correctly, but the noise and errors were annoying at the start. I tried to solve the problem by adjusting the belt tension, squaring the gantry etc. The solution that worked was to remove all the screws from the linear bearings on both sides and tighten them back in place, carefully lifting the rail to maximize the gap between the linear bearing assembly and the frame. After that, everything started working normally again and homing takes only couple seconds. Only reason I can come up with this is that the linear bearings were somehow stuck.
Linear bearings & screws I took off (last pic): https://help.prusa3d.com/guide/5-corexy-assembly_835522#844219
Linear bearings & frame (Gentry/linear rail is missing from the picture): https://help.prusa3d.com/guide/5-corexy-assembly_835522#844328
Linear rail (2nd pic): https://help.prusa3d.com/guide/5-corexy-assembly_835522#845609
Esta publicación ha sido modificada el hace 5 months 4 veces por hämppis
Respondido : 13/12/2025 9:40 am
@jsb It's hard tp make reasonable suggestions without some evidence - please supply a picture of a failed print *on the print sheet* and another showing the underside of the same print after removal.
Benchies (and before them, Bunnies) used to be standard torture tests for diagnosing printer problems; unfortunately there are now so many unregulated variants of these files that their utility has almost evaporated - to get the original, useful Benchy file go to: https://www.3dbenchy.com/
If your printer is shaking hard you might be printing one of Prusa's high speed Benchies - there are party-trick 'Look how fast we can do it' versions proliferating that will shake any printer OR you may have a perfectly ordinary Benchy file and a resonance problem.
To check for resonance, move the printer, temporarily, to another surface, even the floor will do and see if the vibration continues.  If the printer is quiet the answer is simple, put it on a different table or if that is not possible look up the 'concrete paver' solution. [It's not a matter of the strength of the table, it's the frequency at which it naturally vibrates accidentally matching that of one of the printers moves.]
Respondido : 13/12/2025 2:06 pm
jsb
 jsb
(@jsb)
@jurgen-7: Yes, built from the kit. Fails the homing test "failed to calibrate homing". All other tests passed. Yes, completed the gantry alignment and belt tensioning. However, the belt tensioning is suspect. I can't get the android app to give consistent results, but the new stroboscopic method in 6.4.0 seems to work - except the lower belt never waves! only the upper belt. Even when testing the lower belt, only the upper belt shows the waves. That seems to point to an issue with the lower belt, even though the tensioning test passes. I'll add more in another response.
Respondido : 13/12/2025 2:17 pm
jsb
 jsb
(@jsb)
Here is the failed Benchyrules print from the included usb stick from Prusa. The keychain also failed late into the print by just petering out, but I don't have a photo.
Respondido : 13/12/2025 3:00 pm
jsb
 jsb
(@jsb)
Lower belt tension is suspect. When I use the FW 6.4.0 stroboscopic tensioning, only the upper belt "waves" when the printer is checking the upper AND lower belts. The lower belt never waves.  What would cause that? Also, the lower belt tensioner needs many more turns than the upper to pass the tensioner test.
Respondido : 13/12/2025 3:03 pm
Posted by: @jsb
Never turn the tension screws independently of each other. Doing so will bend the gantry. I would start by completely loosening the belts but just before the screws come out of the tensioner pulley nut. Next check that the gantry is still square. If not, bend it by hand until it is. Next tighten both screws by the exact same amount. Starting with one screw, do two full turns then move to the next screw and also do two full turns. Continue until the belts start to get tight then do only 1/2 turns but again both screws. I find it helpful to use the audio app until the belts are in range (plucking as you turn the screws) then switch to the strobe.
Respondido : 13/12/2025 6:44 pm
jsb
 jsb
(@jsb)
Turns out my inexperience with belts had them too loose such that they were out of range for the tensioning apps. Chatting with support and sending pictures and videos, once I got the tension in range I got reliable strumming and strobe results for the first time and got a nice first print. Thanks for all the help from the forum!
Respondido : 14/12/2025 1:11 am
Posted by: @jsb
Good you were able to get it sorted. What is helpful is to run the belt tension wizard on the firmware and just before the step where it vibrates the belts (with the head locked into position), pluck the top and bottom belts and remember the sound/frequency/note. When I do maintenance and retighten the belts I can get them into range just by the sound alone. Then use the wizard dial in more  accurate frequencies.
Respondido : 14/12/2025 3:56 pm
mnentwig
(@mnentwig)
just to reiterate: The gantry alignment (perpendicular with loose belts, then still perpendicular with belts under tension, then tightened to the correct tension as measured by the wizard) is key. Fortunately, an incorrect result is easily measurable. That is, resonant frequencies not on spot, gantry not perpendicular => can't be worked around, fix the root cause before moving on.
The gantry alignment may require use of controlled, moderate force to bend the sheet metal parts per the instructions. This may feel intuitively wrong at first, but a dialed-in printer requires tighter tolerances than (cost efficient) manufacturing allows so the parts need to be "calibrated" manually.
Respondido : 14/12/2025 4:08 pm
