Core One Assembly running out of M3x6 screws at putting the linear rail?
JMars
(@jmars)
Mitglied
Anyone run into this problem, I am at assembling the linear rail and I found myself running into short of three M3x6 screws?
How many more would I need to finish the assembly? Anyone run into this problem or its only me missing parts?
Veröffentlicht : 14/09/2025 1:18 pm
Stef86
(@stef86)
Mitglied
RE: Core One Assembly running out of M3x6 screws at putting the linear rail?
Hello,
For my part, the M3x6 bag indicates that there are 38 screws, and at the end of the assembly, I have 7 left. Perhaps there was a mistake in the previous steps and some M3x6 screws were used incorrectly?
Rereading the manual, it shows that 31 M3x6 screws are used. So I have 38-31=7.
Veröffentlicht : 14/09/2025 3:35 pm
Posted by: @jmars
No, didn't have an issue but then before I started I emptied all of the bags into ice trays with labels for each type of screw and did a count.
Veröffentlicht : 14/09/2025 4:01 pm
Tim
 Tim
(@tim-24)
Mitglied
Posted by: @jmars
If you did a parts inventory prior to starting the build ... any chance you used the screws in the wrong places? E.g., used 6mm when you should have used 8mm?
Those types of mistakes aside, its possible you received a bag from a returned printer kit, where the original purchaser mis-packed things and you received that used kit.
Diese r Beitrag wurde geändert Vor 3 days von Tim
Veröffentlicht : 14/09/2025 5:23 pm
