Core One + Assembly kit first power-up no LCD
I just finished building the Core One + Kit. I powered it up and LCD stayed black. Some LEDs under the LCD are blinking (green and other colors).
I lookes around and people talk about reseating the LCD cables. So I tried reseating them, first at the LCD with no luck and then at the mainboard still no luck.
I found that I could make it worst thoug. Getting a flashing red light under the LCD for instance and what seems to be a non bootable system if powered-up with a USB thumb drive.
I think I managed to get a firmware update (the latest from March 2026) as it booted, some lights under the LCD and rebooted.
I`ve never seen anythin on the LCD, only flashing LEDs under it. Reset button works……. Not sure what to look for now.
Any ideas?
Regards,
Normand
Any ideas?
You should contact support using the chat link and ask them to walk you through fixing the issue. It possible the ribbon cable is not correctly inserted.
