Challenge homing and Z height with ABS print
Frank
(@frank-2)
More of an annoyance, but hey
Loadcell system works fantastic for PLA and PETG, but when I tried to print ABS, it had difficulties cleaning nozzle (it was clean) and it failed at its calibration points. After retrying it worked. Happened twice, with 2 different prints.  Both cases, after retry print came out flawlessly with perfect adhesion. Anybody see the same ?
Napsal : 24/02/2025 12:49 pm
snakefaith
(@snakefaith)
RE: Challenge homing and Z height with ABS print
Hello
I have similar experiences with pc. And always when i printing
Napsal : 02/03/2025 2:06 pm
Frank
(@frank-2)
Same here. Once homing does work, the print is flawless, but with ABS homing/cleaning nozzle is a pain in the lower back
Napsal : 06/03/2025 5:17 pm
snakefaith
(@snakefaith)
Hello
Problem solved
I bought the One so I could print PC ABS etc. That's why the chamber is always 50-60 degrees. I had a continuous nozzle cleaning problem. Then homing loop, and crash detection. And finally it said that the x y belt was loose. I tightened it up and no problem since.
Napsal : 15/03/2025 4:46 pm
