Benchy Benchmark
ifeelhorst
(@ifeelhorst)
Membre
Benchy Benchmark
I just assembled my kit and printed the Benchy. What do you think? Which adjustment screw should I optimize further?
Thx for your support.
Horst
Publié : 31/12/2025 1:31 pm
RE: Benchy Benchmark
I'm going to guess that this is PLA maybe? Which filament and manufacturer would be helpful.
I wouldn't mess with the idler screws. If anything, it looks under-extruded.
Would be helpful to attach a zipped 3MF file.
Publié : 31/12/2025 10:23 pm
Anyway, your Benchy looks fine
Publié : 31/12/2025 10:33 pm
Sorry, what I meant to say was: "Anyway, your Benchy looks under-extruded"
Publié : 01/01/2026 12:26 am
ifeelhorst
(@ifeelhorst)
Membre
thx for your reply. I used the default benchy from the usb Stick. My filament is from ESun. It was pretty fine with my old MK3S.
but it‘s a very good hint that too less filament come out.
Publié : 01/01/2026 8:44 am
I would rate that print as good enough for the first month.
Every user builds their printer slightly differently and pre-built models are shaken up in transit so during the first few weeks of use the printer will run-in and settle its parts together; then you will have to go over the basic maintenance checks, lubricate and recalibrate. Even if you got everything dialled in perfectly today, it would all need re-doing.
Better to settle, temporarily, for a basic working printer and get some useful printing done, make your early mistakes, establish a routine and generally get used to the process. Then when you do your one month service you can take extra care knowing the new settings on your now stable printer are likely to last for several months.
Publié : 01/01/2026 12:03 pm
1 personnes ont aimé
XY positioning looks very good -- no need to mess with belt tension, gantry alignment, input shaper etc. I think.
As @hyiger wrote, the top layers look like they did not get quite enough filament. Did you print the pre-sliced Benchy from the USB stick? If so, was the filament you used in line with what the pre-sliced model assumes (Prusament PLA)? Maybe repeat the test print with a matching filament, or load the STL into PrusaSlicer and choose the right filament type for the material you have on hand.
Publié : 01/01/2026 1:29 pm
Conrad
(@conrad-2)
My stick had an 8 minute benchy (bonkers) and a 14 minute benchy. The 8 minute one shows off speed but not super high quality. Not sure what the 14 minute one is for, but you should download the original STL file and slice maybe a 0.15 layer one using the "Balanced" profile that's optimized for the Core One. It should come out around half an hour. PLA should give you the best result (make sure you use a filament profile for the filament you're using) and, hopefully, show you what the printer is capable of, or highlight any problems.
Publié : 03/01/2026 10:51 pm
