Assembly instructions
locus
(@locus)
I have the Core One kit on order - can we get the build instructions posted here so I can see what tools etc Ill need ?
Napsal : 04/02/2025 3:46 am
RE: Assembly instructions
I don't think prusa have released that information yet.
Try the Chat option...   typically in the past, Prusa have provided basic tools wit the kits
however many builders prefer screw driver allen (Hex) wrenches and torx wrenches, to the L shaped tools provided by prusa.  so they may be a good starting point for you, plus a pair of flush cut  cutters to prevent sharp ends on cable ties.
I am hampered by Long fingernails, so I use long nose pliers to pick up small objects...  this may not be an issue for you...
Joan
Napsal : 04/02/2025 10:04 am
2 lidem se líbí
iftibashir
(@iftibashir)
The build instructions will be available most likely as soon as the Kit versions start to ship. They are still being revised and finalised right now.
Napsal : 04/02/2025 11:36 am
1 lidem se líbí
Frank
(@frank-2)
In the past, the supplied tools did allow me to build a Prusa. They are sufficient but not ideal. Not an issue for me, since I have a rather extensive tool cabinet.
Napsal : 05/02/2025 8:09 am
1 lidem se líbí
iftibashir
(@iftibashir)
Yup all tools will be supplied (see my previous build guides below).
However, I would recommend a good set of Hex drivers (including ball end drivers) as this will save you having to use the Allen keys that are supplied with the package, and can get quite annoying to use! The hex drivers will make the process much quicker and easier.....
Napsal : 05/02/2025 8:25 am
1 lidem se líbí
efvee
(@efvee)
Or, if you have another printer, make check Printables for handles of Allen keys.
Posted by: @iftibashir
Napsal : 06/02/2025 8:12 pm
Antimix
(@antimix)
I think that the preparation of the assembly instructions is one of the causes of the kit shipping delay.
I recently noticed on some PRUSA internal process videos on YouTube, that the way they assemble their printers is different than how they tell their customers to do it in the manuals.
For example, they were assembling the MK4S in a different order, using a custom precision geometry guide tool that ensures the parts are square and forces zero tolerance when assembling parts that may be slightly up or down when you screw them in by hand.
The CORE One is complex to assemble, and should be assembled exactly square and perpendicular, so they are probably thinking about how this could be achieved by regular customers who don't have all the special PRUSA tools to facilitate precision assembly. Assembling a critical part of the printer out of alignment because you don't have a good process or special tooling can cause it to fail and result in thousands of support calls. They may even change at the last moment the design of a part, if this improves the capability to be assembled.
This is why I think there are shipping delay in addition to their chronic production delays.
Napsal : 08/03/2025 10:21 am
Posted by: @antimix
Why do you refer to a "delay" there? Prusa has announced that shipping will "start in March". (They actually brought it forward by a month by swapping the order of the full kit and the Mk4s upgrade kit.) As of today, they have not told us that they might miss that target.
It was always planned to ship the fully assembled printers first, then the kit a few months later. I believe that's how Prusa has always approached new product launches. It makes good sense to me to first gather some experience on the internal builds, to become aware of tolerances and alignment issues which kit builders will have to watch out for (and which hence need to be explained in the instructions). A business interest to sell the higher-revenue assembled units first may also play into it.
I don't think that the question "how can customers assemble this without our custom fixtures?" is giving them a major headache. Sure, production will use special jigs and fixtures to make the printers quicker to build. But Prusa's R&D team has probably assembled multiple generations of prototypes and alpha units before those custom tools were made, and have figured out how to do it with standard tools. (Plus maybe some little helpers like the planetary gear alignment tool, which actually get included with the kit.)
Napsal : 08/03/2025 11:44 am
2 lidem se líbí
dteng
(@dteng)
A friend received his Core One Kit a couple days ago, but still no assembly manual available (as far as we can tell)…odd.
Napsal : 12/03/2025 8:08 pm
1 lidem se líbí
Jeroen
(@jeroen-3)
He may have received a pre-assembled Core One, but he definitely did NOT receive a Core One kit.
Posted by: @dteng
Napsal : 12/03/2025 8:15 pm
1 lidem se líbí
dteng
(@dteng)
My apologies, I just confirmed that he changed his order from kit to assembled.  Sorry to get everyone excited about the kits shipping already. 😞
Napsal : 12/03/2025 9:28 pm
1 lidem se líbí
JohnBirdlebough
(@johnbirdlebough)
humm just ordered CoreOne Kit.  Have the tools, I have developed many startup to advanced post graduate level guides.  If Prusa needs help, ping me.   Looking forward to playing with this and building diode laser accessories for X70 Atomstack systems.  Wonder how long it will take to get delivery?
Guess time to start learning slicer and find a usable 3D cad tool.  FreeCAD is just ugly, looking for options.   Any thoughts would be appreciated.
J
Napsal : 13/03/2025 1:28 am
Rainer
(@rainer-2)
I use Fusion 360 or Oneshape. Both are free for private users.
Napsal : 13/03/2025 1:53 pm
efvee
(@efvee)
@JohnBirdlebough:  The modeler best suited for you depends on what you want to make. If I take myself as an example: I have long experience with coding and I make mainly functional things. I thus use, solely, OpenSCAD. What I like is that models are built from the base up every time, you make a preview so if I later find I did something wrong in the early stage, it usually is easy to solve. With other modelers it is often very difficult to 'get back'.  Also I like the compact instruction set and the ease to make exactly those extension modules you need for the project.
Be sure to use a recent daily build, available on GitHub. Extensions relative to the latest formal release are a much faster render engine and the possibility to send the model directly to the slicer of your choice.
Napsal : 13/03/2025 4:28 pm
Grogg3D
(@grogg3d)
Core One Kit assembly online: https://help.prusa3d.com/manual/prusa-core-one-kit-assembly_2251
Napsal : 02/04/2025 8:34 pm
1 lidem se líbí
TeamD3dp
(@teamd3dp)
Posted by: @johnbirdlebough
J
There are significant differences between some of the modeling software options.  I agree that FreeCAD is less polished, but that isn't the reason I avoid it.  More established (modern) modeling software such as Fusion360 and OnShape offer some HUGE advantages in easy user parameters, and effective timeline control.
User parameters allow MUCH more dynamic control over your designs for quick iteration changes. When used in conjunction with (properly assigned) constraints, user parameters allow you to make precise adjustments to a model simply by changing a dimension or formula on the parameter table, and your model, and all downstream design elements that reference it, will update automatically.  The constraints portion of this takes some care and attention to get right, but once you understand it how it works it is absolutely invaluable as a significant time (and frustration) saver.
The second point about the timeline is equally incredible, and I don't believe FreeCAD has this either. At any point, you can slide back in time to make changes, add features etc, then pull the slider back to present.  No more worrying about missing a critical step and having to re-model everything from that point.  Just slide back, fix it, then back to the end.
I know Fusion has some limitations unless you pay for it, and OnShape free version makes your models public...but those two features, User Parameters and Timeline control, automatically manage put them far ahead of the others right from the start.
This may not be a big deal if your designs are very simple, but in my opinion, you're likely to wish you had this functionality before long.
-J
Napsal : 05/04/2025 1:39 pm
Chris Hill
(@chris-hill)
Posted by: @efvee
Thank you for this pointer.  I'm a big fan of OpenSCAD, but I had been using an old daily build for quite a while, and the introduction of the new 'manifold' rendering engine had passed me by.  It's a revelation!
Napsal : 05/04/2025 3:24 pm
1 lidem se líbí
locus
(@locus)
Looks like the instructions are posted:
Napsal : 06/04/2025 1:50 am
