XL Memory and LAN issues
tjmaxal
(@tjmaxal)
This might need to be two separate posts but the issues are with the same printer so maybe not. *shrug*
1)
I cannot use my 5H XL without leaving the original usb stick attached to be used for "local storage" I've tried other usb options and while the printer will recognize files it will not accept it as local storage for Prusaconnect to utilize. This means that I cannot utilize the printables integration or connected storage correctly.
2)
Additionally the printer goes "offline" according to connect if it is left idle for some amount of time. The issue seems to occur over night so I'm not sure how long the idle status needs to last for this to happen. Despite show a LAN connection on the device, on my router, abd on Prusa Link, Connect persistently states it's offline. Accessing connect through the app, the slicer, and the webpage all show the same incoorect offline status.
As I said for issue one I've tried various usb sticks without connect being able to use them as local storage. for issue two, I've tried reseting the printer, the network connection, and refreshing connect by restarting the slicer, the iphone app, and reloading the webpage. none of this has resolved the issue so far.
Publié : 10/12/2024 7:31 pm
