Utterly confused by presets, physical printers and prusaconnect/link
DJ
 DJ
(@dj-9)
Miembro
Can someone help me make sense of this?  I have no idea what the difference is between a user preset and a physical printer.  And why do I have to add a new physical printer to use PrusaConnect?
But really, the main thing I want to know is why does the button next to "Export G-Code" change if I select the locked "Original Prusa i3 MK3" profile vs the same printer I set up as a "Physical printer"?   On the original profile, the button says "Send to connect" and it loads the connect UI where I can select these options:
Set ready and Print Now
Add to print queue
Only copy to printer
Schedule delayed start
But on the physical printer preset, the button in that space just changes to a stylized G and the options I have are:
Upload
Upload and print
I think Prusaslicer needs a simplification of this convoluted process.
Respondido : 09/02/2026 3:46 am
Ibashyougood
(@ibashyougood)
RE: Utterly confused by presets, physical printers and prusaconnect/link
You are not alone. I have always been told to use physical printers if I want to send files directly to the printer. When I now changed from a 0.4 nozzle to a 0.5 I had no access to my filament profiles since they were locked to the 0.4. I also needed to remove my Prusa connection to that printer and add it again. From what I have read, the physical printer is the old way of doing it, but I have no idea if that's true or not. I just want to have access to my filament profiles and be able to change nozzles to different sizes now and then, but confused on how to set everything up.
Respondido : 14/02/2026 12:52 pm
Nonoobybut
(@nonoobybut)
Miembro
imho you have to do a new printer profile because a 0.5 nozzle will possibly create a higher flow, i changed to a 0.6 HighFlow nozzle and the smallest layer height option is 0.2 then while enabling a 0.35 speed option, the filaments have a 0.4, a 0.5 and a 0.6 option with different speed settings, cooling fan etc. I think this is to protect you from printing with not fitting parameters 🤷‍♂️
Respondido : 22/02/2026 5:01 pm
