Stopped receiving/seeing telemetry in Prusa Connect
Petri
(@petri-2)
Hello, few days ago I stopped seeing telemetry from any of my three printers. It is the same with all three printers I have connected to Prusa Connect. Telemetry vertical axis just shows "Fan RPM", but there are zero data points and the graph is empty.
Are others seeing similar behavior or am I alone with this?
This occurs both in Prusa Connect via slicer and Prusa Connect via web.
I can see other data coming through just fine, such as individual metrics like nozzle temperature and bed temperature in the header and on the control view, so connectivity in general should not be the issue. Prints also go through fine from slicer to the printer. Printers have been restarted multiple times with no impact.
Opublikowany : 27/10/2024 7:28 am
Petri
(@petri-2)
RE: Stopped receiving/seeing telemetry in Prusa Connect
OP here. Telemetry is back. I did not change anything from my side. Must have been a fluke, who knows.
Opublikowany : 28/10/2024 8:04 am
