Slow Transfer from Connect to MK4S
MJR10
(@mjr10)
Hello,
since half a year the transfer is very slowly. It takes 30 minutes to transfer a 200kb file from prusa connect to my MK4S. I did not change the location of the printer nor the access point. I can remeber times it took only seconds and a 10MB file was transfered. Is there any known bug or anything i can do to speed up?
Thanks in advance.
Michael
Opublikowany : 27/08/2025 7:10 pm
_KaszpiR_
(@_kaszpir_)
I suggest checking if the computers next to the printer have similar issues with the transfers.
Some things to test: reboot the access point, reboot the printer, check if any other wifi networks are nearby and are maybe on the same channels ( change to the least busy channel), check if the access point got stuck on some colliding or slow networks ( few times I saw access points loosing cables and they switched to the mesh via 2.4GHz connections on busy channels and this turned speed to a crawl, force switching to 5GHz and later cable helped).
If that does not help then seems like the module may be a culprit, then talk to the prusa help via chat.
Opublikowany : 28/08/2025 7:21 am
MJR10
(@mjr10)
RE: Slow Transfer from Connect to MK4S
Pc and smartphone connection is fine, also the wifi sign on the printer shows full connection.
Opublikowany : 28/08/2025 8:11 am
Crab
 Crab
(@crab)
Do you have the binary gcode enabled?  Maybe this got disabled in an update. Assume you’ve cycled power to the printer.
Opublikowany : 28/08/2025 2:04 pm
MJR10
(@mjr10)
Hiw can i do that?
Opublikowany : 28/08/2025 4:07 pm
