Prusa connect, how to delete the files on the queue list? And how to take automatic spool 2 of the XL printer when spool 1 is empty?
Who can help me?
Thank you all
Opublikowany : 17/11/2024 11:29 am
RE: Prusa connect, how to delete the files on the queue list? And how to take automatic spool 2 of the XL printer when spool 1 is empty?
In Printer files the 3 dots on the right side of the file says "delete".
You must use the usb drive manually. Insert it into the controller, when the printer promps you for the spool (I think it asks what spool you want) turn the nob all the way to the left to select the number 1 or 2, push on the knob and it will bring up JOIN SPOOLS in the window. You must do this manually and every time you print.
Opublikowany : 19/11/2024 1:59 pm
Can you explain to me where i find the files that i have to delete in order for the Download queue file error to disapear?
Thank you
Opublikowany : 26/12/2024 6:45 pm
1 ludzie polubili
Similar problem here.
I have 132 files in *Drucker Dateien* and I can click on *Transfer beenden* at each file.
Is there a way to delete *all at once* ?
Any help is appreciated,
Matt
Opublikowany : 19/02/2025 2:59 pm
1 ludzie polubili
