Is it not possible to cancel a print using Prusa Connect while the "Stuck Filament detected" warning is active?
Gingerbreadmen
(@gingerbreadmen)
Miembro
Hi everyone,
hopefully someone can help me with this, I'm starting to feel like an idiot because I cannot believe this is not possible.
I started a longer print before leaving the house earlier, as my MK4S as been performing almost flawlessly ever since i got it and I thought "worst case I'll just cancel it through Connect"...
I just got the "Stuck Filament detected" warning, and since I'm not home I cannot unload the filament. So, I obviously just want to cancel the print and try again once I'm home, but neither the "Cancel" button for the job nor the "Reset" button for the printer work! I always get either "unknown error" or "command rejected by printer" responses...
Is it really not possible to cancel a print/set temps to "Cooldown" while this warning is active?
Respondido : 28/05/2026 12:04 am
