Home Assistant Add-on for Streaming RTSP Cameras to Prusa Connect
porcus3D
(@porcus3d)
## Overview
For those who use Home Assistant alongside their Prusa printers, I've created an add-on that makes it simple to stream any RTSP camera to Prusa Connect for remote monitoring.
This is a wrapper around the excellent [Prusa-Connect-RTSP]( https://github.com/Knopersikcuo/Prusa-Connect-RTSP) project by Knopersikcuo, packaged as a native Home Assistant add-on with full UI configuration.
## What is Home Assistant?
Home Assistant is an open-source home automation platform. If you're not familiar with it, think of it as a central hub that can control and monitor smart home devices, cameras, sensors, and more - all from one interface. Many in the 3D printing community use it to monitor printers, control enclosure lighting, manage temperature sensors, etc.
## Why Use This?
**Problem**: You want to monitor your Prusa printer remotely using Prusa Connect, but:
- You don't have a Prusa-branded camera
- You already have an RTSP camera set up
- You want to use existing cameras you have around the house
- You want more flexibility in camera choice
**Solution**: This add-on lets you use ANY RTSP-compatible camera with Prusa Connect!
## Features
- **Wide Camera Compatibility**: Works with Wyze, Reolink, Hikvision, Tapo, Thingino, and any other RTSP camera
- **Multi-Printer Support**: Monitor multiple printers with different cameras
- **Easy Setup**: Configure everything through Home Assistant's UI
- **Timelapse Support**: Automatically capture and generate timelapse videos
- **No Hardware Hacking Required**: Pure software solution
## Installation
If you're already running Home Assistant, installation is simple:
1. Click this button to add the repository:
[![Add Repository]( )]( https://my.home-assistant.io/redirect/supervisor_add_addon_repository/?repository_url=https%3A%2F%2Fgithub.com%2Fschmacka%2Fhomeassistant-addons)
2. Install the "Prusa Connect RTSP Camera" add-on
3. Get your Prusa Connect token:
- Log in to [connect.prusa3d.com]( https://connect.prusa3d.com)
- Go to your printer's settings → Camera section
- Click "Add new other camera" and copy the token
4. Configure with your camera's RTSP URL and token
5. Start monitoring!
## Configuration Example
```yaml
cameras:
- name: "MK4 Enclosure Cam"
rtsp_url: "rtsp://192.168.1.100:554/stream"
token: "your-prusa-connect-token"
upload_interval: 5
timelapse_enabled: true
## Real-World Use Case
I use this with a Thingino camera pointed at my MK4. The camera streams over RTSP to Home Assistant, which then forwards frames to Prusa Connect. This gives me:
- Live monitoring through Prusa Connect app
- Timelapse videos of my prints
- Integration with my existing smart home setup
- No need to buy Prusa-specific camera hardware
## Requirements
- Home Assistant installed (on Raspberry Pi, NUC, or any supported hardware)
- RTSP-compatible camera on your network
- Prusa Connect account
## Credits
This add-on wraps the [Prusa-Connect-RTSP]( https://github.com/Knopersikcuo/Prusa-Connect-RTSP) Python application by Knopersikcuo. All credit for the core streaming functionality goes to the original author!
## Links
- **GitHub Repository**: https://github.com/schmacka/Prusa-Connect-RTSP-HA
- **Add-on Repository**: https://github.com/schmacka/homeassistant-addons
- **Upstream Project**: https://github.com/Knopersikcuo/Prusa-Connect-RTSP
- **Home Assistant**: https://www.home-assistant.io/
## Questions?
Feel free to ask if you need help getting this set up or have questions about compatibility with your specific camera!
Happy printing! 🖨️
This topic was modified 5 months temu by porcus3D
Opublikowany : 15/12/2025 5:57 pm
2 ludzie polubili
Dreffi
(@dreffi)
RE: Home Assistant Add-on for Streaming RTSP Cameras to Prusa Connect
Hi, I just got the add-on working.
If I set timelapse to enabled, where will the media be recorded?
Is there any way to control the timelapse from within home assistant, like based on the printer status?
Opublikowany : 07/02/2026 2:54 pm
