Feature Request [Prusa Connect] - Ability to rename files/history items
[Gelöst] Feature Request [Prusa Connect] - Ability to rename files/history items
ReeDoet3D
(@reedoet3d)
I often send large amounts of platters sliced to connect for queueing, but every platter is named after the last saved project. Since you can not close the project in Prusa Slicer, actively "Save As" or close and re-open Prusa Slicer is the only way to get rid of the project name.
So I have, for example, drawer cabinets in my history that have the name "Camera Mount", making reprint a hassle.
If only we could rename the items in the history; then reprint without re-slicing or confusion would be possible.
Veröffentlicht : 01/09/2025 11:37 am
Feature requests here will probably not be seen by the Dev team.
The best place for such requests is Prusa's Github.
Veröffentlicht : 01/09/2025 12:27 pm
ReeDoet3D
(@reedoet3d)
RE: Feature Request [Prusa Connect] - Ability to rename files/history items
Unfortunately, there does not seem to be a repo for the Connect website, so hopefully Prusa does come here now and then 😉
  • Prusa-Connect-SDK-Printer - for adding printers to Connect
  • Prusa-Firmware-ESP32-Cam - for cameras to be used in Connect
  • Prusa-Connect-Status-Test - empty repo
nothing else with "Connect" in the name.
Thank you for suggesting it, though. Much appreciated.
Veröffentlicht : 02/09/2025 5:25 pm
ReeDoet3D
(@reedoet3d)
Well, apparently it is already possible, though it's not where I would have expected it.
Case closed 🙂
Veröffentlicht : 07/09/2025 5:36 am
el.axe
(@el-axe)
Mitglied
Thanks for this thread! It's indeed a bit weird that renaming is not available under "Connect files" but not via "Printer files". It seems that renaming under "Connect files" does not propagate to the ones stored on your printer and does only affect the cloud-hosted storage.
Diese r Beitrag wurde geändert Vor 2 weeks von el.axe
Veröffentlicht : 19/04/2026 10:02 am
