Duplicate file blocks newer files to printer
gtomr
(@gtomr)
When I send a file it goes to Prusa connect instantly.  When Connect sends to the printer it either doesn't delete from the Current Transfers list or  it duplicates the file.  Current Transfers then says "The File with the same name is already present on the printer"  That block new files from being transferred to the printer.  I have to click on "Stop Transfer" and wait until it takes before the new file will be sent to the printer.
I also noticed that the printer's current status is not updating.  I have to go to a different screen and then go back.  I don't know if the issues are related.
Napsal : 15/02/2026 11:59 pm
djplanc
(@djplanc)
RE: Duplicate file blocks newer files to printer
same here, getting a bit annoying
Napsal : 17/02/2026 8:40 am
Henrik
(@henrik-6)
Same issue here
Napsal : 17/02/2026 2:41 pm
match-Codebase
(@match-codebase)
Napsal : 17/02/2026 2:48 pm
Nathaniel
(@nathaniel)
Same happens to me. To be clear this is not a case of uploading a different file with the same name but rather adding a file that already exists on the printer to the queue. Meaning I get this issue even when I use the app to find existing files on the printer and add them to the queue. The system tries to transfer the file to the printer and blocks the whole queue.
Napsal : 19/02/2026 1:52 pm
