Camera thought (low hanging fruit) - allow streams
masterprompt
(@masterprompt)
I get prusa connect is still young.  I want, so badly, to wait for it but we cant.  we have several people that share our printers at the shop.  We have been using octoprint for everything until the MK4 came in and we have lots of issues using octoprint with it.  We tried out prusa connect and the lack of video is a hard pill to swallow.  As a software engineer I get it; paying for ice servers and such for stream capabilities isnt in the budget.  Also, the MK4 doesnt support adding a camera to it.
Compared to our x1c (Im sorry, but now that we have one, I cant avoid comparing) the lack of management software for the prusa stuff sucks.  our prusa's are workhorses, and we want to continue to use them.
Thought: allow us to add a/multiple stream url to our printer in prusa connect web ui!  Doesnt matter where it's coming from, just embed it!  Then we can setup our own streams (octoprint via octoeverywhere or whatever we want) and you don't need to natively support the camera stuff until you're ready. This allows the rest of us who need this feature to adopt prusa connect sooner.
Thoughts?
Napsal : 08/08/2024 4:37 pm
3 lidem se líbí
lambert
(@lambert-2)
RE: Camera thought (low hanging fruit) - allow streams
Hello,
exectly what I wanted to do - user the camera-streams from my RepetierServer. Just empeded!
Using a mk3.5 with a MMU3
Thanks and greetings
Lambert
Napsal : 27/08/2024 7:33 am
_KaszpiR_
(@_kaszpir_)
Then try to do mediamtx server locally with IP cameras? Or something like frigate or other CCTV derivatives?
Napsal : 27/08/2024 7:55 am
1 lidem se líbí
lambert
(@lambert-2)
Hi, THX FOR YOUR REPLY!
one my local repetier server I have 2 cameras. Both have an url where I am able to view the stream. How can I access those from within prusa connect? I HAVE NO CLUE
Napsal : 27/08/2024 8:59 am
_KaszpiR_
(@_kaszpir_)
In short - PrusaConnect does not support video streams, only static image captures.
So you could add another integration to do that, by using frmpeg stream image capture to upload it to PrusaConnect,  see https://nvtkaszpir.github.io/prusa-connect-camera-script/ for more options.
Napsal : 27/08/2024 6:24 pm
masterprompt
(@masterprompt)
correct, we all know that!  But it ...could... support embedded video streams (easily).  Just needs to be a priority.
Napsal : 27/08/2024 6:29 pm
2 lidem se líbí
lambert
(@lambert-2)
Hi, thanks for your explanation.
I will check that!
Lambert
Napsal : 27/08/2024 7:41 pm
lambert
(@lambert-2)
Hello,
I read the docs but couldn’t believe it. Got the confirmation here. No usb cam support.
So your ideas to use an ip camera or use a link to a steam is something that could be implemented simple ( I think so …).
I really want to use prusa connect. But without camera support I think I will continue with repetier Server on the raspberry with my 2 cams.
Is there an enhancement request for your stream embedding idea?
greetings
Lambert
Napsal : 27/08/2024 7:52 pm
_KaszpiR_
(@_kaszpir_)
About usb cam support in my script- my code supports USB cams connected to linux systems - rasberry pi or other laptops, just needs different config options (the easiest is fswebcam) via capturing single frame and uploading it to the PrusaConnect. Working with camera streams over USB is alsob possible but requires something like mediamtxt + ffmpeg.
About streaming request:
Streaming service is much more complex than just sending image snapshots, also it is much more expensive, I'm not sure if Prusa eager to implement it.
Embedding streams in the app is not that easy especially if you want to have limited access to the stream so it is a bit more complex than it sounds.
Napsal : 27/08/2024 8:04 pm
masterprompt
(@masterprompt)
Posted by: @_kaszpir_
senior level software engineer here: That's not the request in this thread, it's to allow embedded streams.  We can figure out where they come from, if we want security around them, and so on. All Prusa connect has to do is similar to how it allows an image snapshot, just show the stream url embedded in a browser player.
Napsal : 28/08/2024 2:06 am
2 lidem se líbí
lambert
(@lambert-2)
Yes thanks for the correction!
Napsal : 30/08/2024 3:27 pm
_KaszpiR_
(@_kaszpir_)
I that case it may be easier just to allow embeds because of the required work on the backend, yet it will require to decide what type of streams to allow. Some streaming cams are use custom protocols (or not so modern one), so they would probably have to limit what they want to allow forcing people to use only a subset of modern cams (and saving themselves a headache from broken devices).
Still it would require some minor changes in the backend to add extra fields so that user could save the settings and so on.
Will they do it? no idea, time will tell.
Napsal : 31/08/2024 7:21 am
HuG
 HuG
(@hug)
Same request here. Please allow embedding. camera stream on the printer screen.
Context : Just started testing connect after a few years using another app (the one with an octopuss). I like a lot the connect approach, that is a good fit when you want to increase productivity.
The camera stream is the main regression compared to my previous gig. It is really useful to check the status of prints and potentially detect quality issues upfront.
Napsal : 06/10/2024 12:53 pm
sdownie
(@sdownie)
Recently, I received my Prusa XL 5T printer along with the Prusa XL enclosure. I am looking into the best way to mount a streaming camera inside of the enclosure, to view videos of the build process. I believe that an endoscopic camera would work the best, so I am wondering if others may have done this and what issues I should consider along with which cameras are best for this task. From my research, it appears that Prusa Connect does not support streaming, which is too bad, but  I can use a properly configured Raspberry Pi to show me the video stream.
Thanks in advance for any advice you can share.
-- Steve
Napsal : 26/10/2024 6:11 pm
_KaszpiR_
(@_kaszpir_)
@sdownie such question rather should be in the separate thread in this forum section or Prusa XL forums section, not in this thread.
Napsal : 26/10/2024 11:30 pm
Xayoz
(@xayoz)
YES, this exactly...Currently using ESP32 and it...ok.,..but I really miss streaming from octoprint.  Would be great to connect a cam and stream directly, but lacking that option, would be satisfied with an embed link that I could set up myself as described by you fine folks.  I understand Connect/Link is still very new, but I can't believe how far behind everyone else these guys are on that end of things.  Printers are great, slicer is great, remote connections are suboptimal at best.
Napsal : 03/11/2024 1:02 pm
Printeyy
(@printeyy)
Imagine my disappointment when I bough esp32cam only to see how the things are going, see stream on my localhost and find out I can see only veeeeeery-low snapshot each 5 seconds, with some delay when connected to Prusa Connect.
Is there any other solution to monitor that? I know I can just steam in local network and use VPN to see that besides prusa connect. Also do recommend anything better that ESP32-cam?
Napsal : 12/01/2025 2:18 pm
_KaszpiR_
(@_kaszpir_)
esp32 cameras are generally slow, and it gets even slower if you increase the resolution and if you have low light conditions.
PrusaConnect accepts images not more frequently than 10 seconds, which is good enough for esp32 cams.
other options are just more expensive but more performant, some people use Raspberry Pi Zero W or other models with better cameras and this allows full HD streaming over LAN/VPN, but requires custom config.
or standalone cams such as Eufy and so on, but that's 10x more expensive than esp32 cam (at least)
Napsal : 12/01/2025 8:33 pm
3D Troy
(@3d-troy)
+1 for this idea of adding embedded streams to the web page.  I also asked for this for Prusa Link.  Allow us to add some small number of URLs per printer, and then embed those in the browser window.  I can run Pi's with camera servers on them and the stream doesn't go through the printer that way too.
Napsal : 07/02/2025 1:06 am
bwees
(@bwees)
+1 this would be a great addition. It could be similar to how the camera embedding that Mainsail with klipper does. You just give it a URL and what kind of stream it is (if we could just get MJPEG that would be more than enough) and it just embeds that URL in the window. Obviously it would require the user to setup a camera in a manner they could always access (port forwarding, VPN, Tailscale, etc) but that should be fine if you just made a "Normal" camera that uses the current system and an "Advanced" camera that is this new MJPEG embedding method.
Napsal : 20/02/2025 1:27 am
