Core One Belt tuner gauge not working (Android)
baztm
(@baztm)
Just tried out the Core one belt tuner but the bar value was not changing on Android. App has permission for mic. I tried the XL tuner after and it was registering Hz perfectly. Just not on the Core One.
Opublikowany : 10/02/2025 8:50 pm
PaulGregg
(@paulgregg)
RE: Core One Belt tuner gauge not working (Android)
I'm also finding the app just doesn't work. I've flicked, plucked hundreds of times.... once it said 82Hz on one side, but it basically says 0Hz every time I try it.
Mic permission is on - and tested against a 85Hz tone on youtube which the app correctly displays as 84-86 hz (it bounces around a bit).... but I cannot make the Core One make enough tone/etc for the app to register it.
Opublikowany : 13/03/2025 12:50 am
PaulGregg
(@paulgregg)
Replying to my own post....
Figured it out, basically the belts were just too loose, I turned them both clockwise half a turn, nothing, then another half a turn each - then the app started recognising it.  The left was always higher than the right, so I tightened the right only to find the left would also go up, so ended up loosing the left one / tightening the right until both fell into balance at 85Hz. Perfect.
I've done several dozen prints (can't tell exactly, but info says 1km, 1000 metres!, of filament and never had any complaints about the output. Only a couple of failures. Def some VFAs, but minor - you really had to look for them.   Looking forward to seeing how the tuning improves things.
Opublikowany : 13/03/2025 1:37 am
