MK3S+ and display inside the Enclosure
ChrisK
(@chrisk)
Does the MK3S+ with its display fit inside the enclosure?
Opublikowany : 09/10/2022 4:36 am
RE: MK3S+ and display inside the Enclosure
Every photo I have seen has it mounted on the outside.  I do not have mine yet but I think it is made to mount on the outside.
Opublikowany : 10/10/2022 11:52 pm
ChrisK
(@chrisk)
Actually, the answer is right  on Prusa's site.  They give the enclosure dimensions with the LCD mounted inside or outside.
https://www.prusa3d.com/product/original-prusa-enclosure-3/
Dimensions with the LCD mounted outside: 530 mm (w) × 545 mm (h) × 715 mm (d)
Dimensions with the LCD inside: 530 mm (w) × 545 mm (h) × 640 mm (d) At least 250 mm is required in front of the enclosure for the doors to fully open
Opublikowany : 11/10/2022 2:18 am
anza i halfabee polubić
