Is the Smart Box a dead project?
Strona 1 / 2
IBNobody
(@ibnobody)
It's been quite some time since the enclosure was announced, and the smart box is still listed on the enclosure's project page. Is it still being developed?
Smart Box
Optional electronics that serve as an interface between the MK3S+ and various add-ons, mainly the advanced filtration system. The Smart Box will allow communication with various additional equipment, such as advanced thermal sensors, RGB LEDs, humidity meters, a microparticle sensor and also an electronic lock. All the devices can work together, so, for example, when the printer finishes a job, the RGB LEDs will signal the print is done. However, the door will remain locked and the advanced filtration system will increase the power to maximum RPM to clean the air in the chamber quickly. Once the sensors detect the conditions are optimal, the electronic lock is automatically released.
Opublikowany : 20/06/2023 7:13 pm
1 ludzie polubili
RE: Is the Smart Box a dead project?
Might be a good question to ask during Prusa Live.
Opublikowany : 21/06/2023 3:14 pm
1 ludzie polubili
Mattchu
(@mattchu)
Definitely looking to tune into Prusa Live this week, as this is one of my questions as well. I've got two enclosures: they're great, but the smart box definitely feels like something they've sidelined for whatever reason :/
Opublikowany : 28/06/2023 3:19 am
Lofty3D
(@lofty3d)
Did you guys end up hearing anything on the smart box? Weighing whether to wait for this, buy the white LEDs, or just go for a cheaper lighting solution. Thanks!
Opublikowany : 05/07/2023 2:14 pm
Hello
(@hello)
Someone correct me if in wrong but I believe the white led strip has rgbs in already for the smart box
Posted by: @flaherty-j
Opublikowany : 05/07/2023 8:08 pm
Mattchu
(@mattchu)
To respond to both:
@hello, correct, the white LED strip are actually RGBs that are not addressed; the default state for these are in a white mode.  The Smart Box is supposed to allow for RGB controls, as well as dimming I believe. It also will allow for finer tuning with the filtration system.
If you're thinking of DIY yourself on the lights, Adafruit would be my source for anything light related, if you're feeling frisky with the programming end of it; MakeCode is awesome and easy to use. If you're in Europe there's loads of suppliers as well.
Alveo3D helped design the filtration system; so if you're in Europe you can easily get your hands on that since they ship everywhere there (just not the US). The replacement filters are available from several places in the US if you can get one inported, and they'll fit the prusa one.
Nevermore is another solution, if you're feeling DIY; I've not seen one yet built without connecting it to a RaspPi, but I don't see any reason why you couldn't. Go go voron design team ^_^
The tl;dr version; we've been told nothing thus far. My guess is they are trying to make it in house, and squeeze it in between boards; as the XL and MK4 back orders are filled this will probably get pushed forward more. Getting another PnP machine would be insanely irresponsible for Prusa, as it would go silent almost immediately as they receive it and turn it on; that's a lot of capital for little return at this point. Not giving them a reprieve, because we hate silence, but I also can see the issue being a manufacturing one at the moment.
Posted by: @hello
Opublikowany : 05/07/2023 10:12 pm
Lofty3D
(@lofty3d)
Thank you both! I ended up going with the white LEDs since yeah, turns out they’ll work with the smart board as RGBs.
I’m reasonably comfortable with arduino and Adafruit stuff but I didn’t know about MakeCode, that’s really cool. I might have to try it out on a project soon…
Really interesting theory on the manufacturing too. So do they the boards themselves out for fab and then populate and solder in house?
You already addressed my important question, just curious now. Cheers!
Opublikowany : 06/07/2023 2:57 am
1 ludzie polubili
Mattchu
(@mattchu)
So up until 2020 they did a lot of their fabrication outside: Boards, components, extrusion, etc.  I believe the only thing they actually did in house was cut the rods, maybe extrusion. This is why the MK3S and Mini can be sourced so easily; the parts were all off the shelf or produced in a way that was easily accessible.
Part of their 2019/2020 goal was to move as much in house and/or source from locations not in China; with the pandemic this means trying to get common components from European manufacturers who were suddenly VERY behind on orders, as well as trying to make capital expenses (the pick and place machines we've just mentioned).  I believe at this point a massive amount of the XL and the MK4 are now produced in Europe. I'm unsure if they do their own sheet bending or not (I haven't asked); based on the enclosure and the XL, I'd want to say that the answer is a tentative "yes."
I know if you look back through their social media posts, they have videos of their pick and place working;  I'm amused and impressed at the idea of using a PCIe standard for their XL boards, to make swapping/upgrading MUCH easier.
Opublikowany : 06/07/2023 10:01 pm
jseyfert3
(@jseyfert3)
Posted by: @mattchu
To respond to both:
Posted by: @hello
Are they RGB LEDs, or RGBW LEDs? I passed on the white LED strip as $75 for a white LED strip seemed high. If RGB then maybe not. But I'd also be very disappointment to get a white LED strip that turned out to be RGB. This is because while RGB LEDs together look white, they cause terrible color rendition on objects they illuminate.
My plan for my own enclosure is RGBW LED strips. This way I can get cool color effects when I want them, but use the white LEDs when I just want the enclosure lit up so I can see the printer/print, which I suspect will be most of the time.
And yes, Adafruit is where I will buy the RGBW strips, and other components. I really like Adafruit.
Opublikowany : 20/07/2023 6:10 pm
Stsfin
(@stsfin)
Posted by: @jseyfert3
Posted by: @mattchu
To respond to both:
Posted by: @hello
Just installed the filtration and ledstrips, at a quick glanse they seem to be RGBW leds, at least looked through the diffuser.
Opublikowany : 21/11/2023 3:35 pm
Same Old Shane
(@same-old-shane)
Member Admin
Generally speaking, no project has been killed off, and the rest of the addons for the enclosure are still are still planned. The next Prusa Live is November 29th and can always ask on there as well.
Shane (AKA FromPrusa)
Opublikowany : 23/11/2023 7:31 am
Thanks, Shane.  I have had the same question.
Posted by: @same-old-shane
Opublikowany : 23/11/2023 1:29 pm
Johntron
(@johntron)
Is the interface for this available somewhere? Maybe others could create something.
Opublikowany : 24/11/2023 10:18 pm
Ormorr
(@ormorr)
As much as I want to believe Shane, the fact that they announced the Smart Box with the enclosure in May 2022 and stated it would come out later in the year (and that they were already beta testing it), they are way off the mark here for something that is nowhere near as complicated as a new printer (XL). I bought my enclosure with my printer in April of last year hoping that soon they'd say something, anything, about the Smart Box since it had been roughly nine months since release (almost a year from announcement). Ten months later from my purchase and crickets. In a few months it'll be two years since the announcement. Pretty disappointed on that end as I really was hoping for it to come out and possibly even tie in to Prusa Connect/Link as well. Will it still come out? Maybe. Do I expect it at this point? Nope.
Opublikowany : 05/02/2024 2:01 am
EastCoastJoe
(@eastcoastjoe)
It too am very disappointed with the lack of the release of the "Smart Box".   The MK4 and Enclosure is my first entry into 3D printing.  I was thinking to build my own ventilation/filter system for the "Original Enclosure" but spent considerably more money to by the Prusa branded fan and lights so that they would be compatible with the "Smart Box".  It's now nearly a year later after this purchase and still NO smart box.   ;(      Come On... really?    What's just as bad? ... it's also still listed as a feature coming on the Original Enclosure website page.   Honestly, if Prusa isn't going to make this Smart Box... at least take off any reference of it on the enclosure web page.  That would be fair.   Even more fair... release the Smart Box.   It's obviously possible... as an interesting Un"Official" box a user created is a nice tease of what a Prusa version could look like  https://forum.prusa3d.com/forum/user-and-hardware-mods/unofficial-prusa-enclosure-smart-box-project
Opublikowany : 28/02/2024 3:39 am
knmorgan
(@knmorgan)
Has there been any update on the smart box? It has been 3 months since the last message on this thread and, I believe, two years since the smart box was announced.
Opublikowany : 29/05/2024 5:22 pm
Walter Layher
(@walter-layher)
If you want a filtering fan inside your Prusa Enclosure that can do more than just filter particles, has not only a HEPA filter, but also a VOC sensor, can absorb VOCs with activated carbon, offers more RPM control than just on/off, can actually run while printing, you can use a Nevermore Mini. There is enough space for this filter inside the enclosure, click on the image to see it without cropping. I have built a Mini 40mm and a Mini Plus 55mm for my two Prusa Enclosures and they both work very well. I also have bought the Original Add-Ons from Prusa for both of the enclosures (because I believed the promises that better support would follow), but I hardly ever use them. The LED strip is too bright and the HEPA filter can only be used after printing, is too loud and moves too much air to be run during printing. The Nevermore Mini is very silent, you can see on the display how the VOC value goes down when the fan kicks on. I have not noticed any negative effects on the printed parts because of the fan. And the smell from printing ABS/ASA is gone as well.
If you want controllable LEDs and more settings than "way too bright" and "off", you can attach some neopixels inside the upper frame of the enclosure and control them with WLED or, if you have OctoPrint, the plugin "WS281x LED Status". With OctoPrint and its plugins you can use many kinds of sensors, relays, fans together with your enclosure. No need to wait on promises that might come true some day (or not). And the learning of how to do it on the way is just a bonus ... 🙂
Opublikowany : 29/05/2024 9:46 pm
yaworski
(@yaworski)
It seems that there's some confusion regarding the LED strip and its capabilities. If you go to the tutorial on how to assemble the strip in the enclosure, you can actually see exactly what the strip is capable of:
As you can see, there are two separate strips of LEDs in parallel to each other. The big ones are RGB and the small, rectangular ones with yellow phosphorus, are white. Also the strip is not addressable. It's just RGBW with a common anode (probably 5V) and controlled by connecting each component to gnd through a transistor on the control board. The shop page does say about programmable RGB, but it's not about addressable RGB lights, but rather that the SmartBox would probably be plugged into the printer main board and allow programming RGB light from the PrusaConnect/Link or something.
What I wonder is how the SmartBox would control the control board for light strip and filtration system. There are three sockets on the control board. One for the strip, one for the filtration fan and the last one is probably for connecting the SmartBox in the future. It only has 4 pins, so it's not just a simple pass through. It may use something like UART or SPI maybe to control the logic on control board from the SmartBox.
Opublikowany : 10/06/2024 9:43 am
yaworski
(@yaworski)
I've just looked at the control board and there's not any microcontroller on the PCB. So I have no idea how the SmartBox is going to control the RGBW lights and filtration system over a 4 wire connection. Maybe it's going to replace the control board altogether or just use it for the buttons.
Opublikowany : 10/06/2024 10:37 am
Chris Hill
(@chris-hill)
Posted by: @yaworski
The third socket simply provides additional connections for the fan and the LED.  They mirror the main fan and LED connections, and are controlled by the same switches.  So you can add additional lighting, for instance, without altering the wiring to the original LED strip.
https://forum.prusa3d.com/forum/user-and-hardware-mods/further-information-on-basic-board-and-psu-for-original-prusa-enclosure-for-filtration-unit-and-custom-led/#post-691565
Opublikowany : 10/06/2024 1:20 pm
2 ludzie polubili
Strona 1 / 2
