Z Offset Incorrect - Textured Sheet
Ruebarb
(@ruebarb)
I doubt this issue is new or isolated to the C1L and likely since the nextruder was introduced. But coming from the MK3S and manual tuning. I had hoped the promised perfect 1st layer to be true, but as I always suspected it is not.
The Z Offset is way off for a perfect 1st Layer on the textured sheet.
Left, the "perfect 1st layer", right the corrected first layer, -0.03mm. This is PCTG, but same for PETG.
You can create a printer profile for the Textured Sheet and add the -0.03mm to the Z Offset
This topic was modified 2 days ago by Ruebarb
Posted : 06/12/2025 2:20 pm
