Problems printing TPU
Frank
(@frank-22)
Miembro
I'm having problems printing TPU.
The nozzle gets clogged and the printer continues printing in the air.
What settings do you use?
Or is it due to something else?
Thank you for your answers.
Respondido : 25/01/2026 11:17 am
mnentwig
(@mnentwig)
For a start (assuming TPU95, which is considered "easy"):
Try disabling filament sensors, remove the PTFE tube to the head and feed it in through the removed top cover. Looks ugly, works well enough (a broom with some kind of hole might come in handy as ad-hoc-filament guide, no need at least for small prints).
Use manual axis controls to load and purge.
The true danger in my experience comes when the nextruder attempts to unload the material, pushing it back into the PTFE tube. And TPU doesn't like to be pushed... when cleaning the mess from the nextruder wheel you'll truly get to appreciate the crazy resiliency of this material...
I'm sure there are users who print through the regular filament path. But if the above already fails, it'll only make matters more difficult.
Respondido : 25/01/2026 11:35 am
Clogged? or is the filament tangling in the extruder?
It is usual to have to ease back the extruder idler pressure - once set it can usually be left at that pressure for almost all filaments.
https://help.prusa3d.com/article/prusament-tpu-95a-material-guide_899653
Respondido : 25/01/2026 11:40 am
1 les gusta
Frank
(@frank-22)
Miembro
RE: Problems printing TPU
Many thanks for your answers!
Best regards.
Frank
Respondido : 26/01/2026 6:45 am
I never use a high flow nozzle when printing TPU. I use a non-high flow 0.6 or 0.8mm nozzle. TPU 95A is easy to print, just need to make sure you keep it very dry.
Respondido : 26/01/2026 11:56 pm
JeanPrint
(@jeanprint)
Miembro
I tried (properly dried) eSUN TPU 95A with a 0.6 nozzle without any filament path modifications using the PRUSAMENT TPU 95A profile and the print came out flawless.
Respondido : 30/01/2026 2:38 am
1 les gusta
