Heat Creep with Advanced Filtration System
Maik
 Maik
(@maik-5)
Utenti
Hey, I just got my C1L this week and am/was super excited.
The first few prints came out very nice. I only printed PLA so far. After I installed the Advanced Filtration System, things changed however.
I had a lot of failed prints today, which were noticable through a clicking noise in the extruder and reduced to no extrusion at all. I researched and found a lot of similar posts about this issue and figured I am also having a heat creep problem (heatbreak temp above 38).
I now tinkered a bit with the settings and so far I am having success again by reducing nozzle temp to 210 and re-enabling the chamber fans manually, which are somehow not enabled anymore with the filtration system.
Can anybody relate to this issue and share some knowledge? Thank you!
Postato : 10/01/2026 10:46 pm
SovereignSpec195
(@sovereignspec195)
Utenti
RE: Heat Creep with Advanced Filtration System
You're not alone..  This exact situation is happening to me. I have also turned on the fans manually to 50%, print is still failing. I will try reducing the nozzle temps to what you mentioned and report back! Another thing I tried was backing off the tension of the filament roller 1/2 turn, no changes happened either..
Postato : 25/02/2026 3:27 am
If you are getting clogs caused by heat creep when printing PLA, then try printing with the door open.
Postato : 01/03/2026 5:24 pm
