Core One L bad VFA's and really bad ghosting
Page 1 / 2
J-Plasted
(@j-plasted)
i have been through prusa support and they have no idea why its doing it. bit of a sham considering they advertise they "all but eliminated VFA's" and "Flawless precision" these VFAs are so bad i can feel them..
I checked the belt tension, they are within spec, the gantry is not skewed, i did a accelerometer calibration and nothing changed at all.  this is the 2nd prusa core one L i bought had to send the first one back due to faulty linear bearings, and other assembly problems.
Posted : 27/12/2025 8:01 pm
A picture would help.
VFAs are, by definition, extremely fine so if you can feel them there may be something else involved.
Can you supply a file that shows the problem?
Best is a .3mf (zipped) ...
Files > Save Project as
Posted : 28/12/2025 1:24 pm
J-Plasted
(@j-plasted)
RE: Core One L bad VFA's and really bad ghosting
Hi there please see attached for the .3mf i will grab a photo or two in a second i can definently feel the waves in the part from the printer. still waiting on the email from Prusa if they come up with a solution i will let you know too
Top Cover 1 (2)
Posted : 28/12/2025 5:56 pm
J-Plasted
(@j-plasted)
Posted : 28/12/2025 6:17 pm
There's nothing obviously wrong with that file.
I have noticed that a high proportion of those with recent problems are using a BALANCED profile as are you.  I have no reasonable grounds for suspicion but it would be worth checking the output using other profiles and perhaps slowing down the print.
Posted : 29/12/2025 8:05 am
But the "Balanced" profile was specifically introduced and advertised by Prusa as part of their VFA countermeasures. Go figure..
Posted : 29/12/2025 10:31 am
J-Plasted
(@j-plasted)
It's there on all print profiles.. it's a bit rude of them advertise a vfa free machine for it to be full of them
Posted : 29/12/2025 12:02 pm
... and it's (mostly) those concerned with VFAs who use it - some may even apply it automatically when there is no original problem to fix.  I wonder if misuse might increase the problem in the same way that wrongly connected noise-cancelling headphones turn into noise doublers...
It is worth making a comparison either way, perhaps the preset is masking something worse.
...but I am at some disadvantage here as I've never had VFA issues (I may well have had VFAs but I don't notice them and for my applications they never matter.)
Posted : 29/12/2025 12:26 pm
OK, try moving the printer to another bench or even the floor temporarily in case there is some odd resonance-coupling issue.
Posted : 29/12/2025 12:29 pm
J-Plasted
(@j-plasted)
Once it's finished I will try that what's concerning is the prusa agent stated they have never seen these machines ghost before
Posted : 29/12/2025 12:33 pm
Posted by: @j-plasted
I don't think the artifacts look like typical VFAs (belt ripple) found in the Core One. Those should always be "in phase" when the print head is back to the same XY position. But e.g. after the small through-hole, the ripple pattern is shifted, repeating the hole contour for a long time. You mentioned ringing in the original post, but would ringing really keep going for so many periods, with apparently unchanged amplitude?
Since you have already checked the belt tension and done an input shaping calibration -- could it be uneven flow from the Nextruder? Maybe you could try to print a single-layer vertical wall to check whether the "VFA" pattern is a variation in thickness or in position? (I.e. whether a "valley" on one side of the wall correlates with another valley or with a bump on the opposite side?)
Posted : 29/12/2025 12:38 pm
J-Plasted
(@j-plasted)
I will give it a try after it's finished doing it's print luckily it's not cosmetically important
Posted : 29/12/2025 1:01 pm
J-Plasted
(@j-plasted)
So I paused the print and put it on the floor to see if that makes a difference. It hasn't, you should be able to make out the line where the pause happened this is also slowed down to 70mm for the external perimeter and small perimeters
Posted : 29/12/2025 3:43 pm
Ruebarb
(@ruebarb)
Assuming  PETG? Brand?  Is it Dry?  Which filament profile are you using? The overall print quality in the last pic, needs some improvement before you can address anything else.
Calibrate extrusion for the filament profile.
Measure diameter of the filamentMultplier, by using hollow cube, measure the wall thickness,  See Precise Method --> https://help.prusa3d.com/article/extrusion-multiplier-calibration_2257
https://www.thingiverse.com/thing:271736
Print the Cube with 1 perimeter, 2 bottom, no top so you can measure wall thickness.
Once you have the extrusion set correctly, you will need to adjust the temp, use a temp tower, reduce stringing.
After that,
May have to adjust the filament profile settings and slow down the speed some more.
Core One L MMU3, MK3S
Posted : 29/12/2025 5:28 pm
J-Plasted
(@j-plasted)
im using PLA, overture brand (been using them for 4 years with no issue) now onto a different spool. I printed a calibration cube the other day with prusa support, Z is 19,95mm, x is 19.94mm and Y is 20.01mm according to my calipers will need to do another one with no top once the current print is done for wall thickness
Posted : 29/12/2025 6:25 pm
J-Plasted
(@j-plasted)
to be honest with you, slowing the printer down even more goes against prusas marketing on their own website... they cant sell a printer under the guise of "all but eleminated VFA's" and "Maximum speed without a catch" when the vfas are here and if you run it at "Normal" prusa speed it looks like the tracks of a digger.
Posted : 29/12/2025 7:06 pm
J-Plasted
(@j-plasted)
First photo is with a part near the belts looks like a very close match to me (hard to take a photo with the printer on the floor 😅 second photo shows the VFAs in a better light I think
Posted : 29/12/2025 7:54 pm
J-Plasted
(@j-plasted)
for some reason prusa slicer wont let me use the cube you sent with 0 top layers (probably because its already hollow so the inside of the top layer is also a bottom layer ? also it wont do a single width perimeter even when its set to 1 it seems to always want to do two. i could do it in vase mode however that seems to work not sure what the sliver logic does though but it should be comparable right ?
Posted : 29/12/2025 8:09 pm
J-Plasted
(@j-plasted)
Done the cube, coming out at 19.97, 19.95 and 20.01  VFAs still present wall thickness at 0.44mm in the center of each face
Posted : 29/12/2025 8:26 pm
Ruebarb
(@ruebarb)
Thanks for the info and better pic. Overture PLA Pro is what I print most and it is flawless. I've seen VFA in PETG, never in PLA. Here is my 3mf for the cal cube. Has my Pla Pro profile and the cal cube print settings. I'm using a standard nozzle. You'll need to set the extrusion multiplier back to 1.0 and measure the diameter of the filament.
Posted : 29/12/2025 8:35 pm
Page 1 / 2
