ASA Help.....
Steve S.
(@steve-s-3)
ASA Help.....
OK we have 6 Prusa Printers.    We have an ASA print that prints great on both of our XL Printers, but warps everytime after 50% has been printed on the core one L.
We use the same filament across all printers - Polylite ASA
Vent is Close
Open to suggestions.....
Napsal : 08/06/2026 10:12 pm
mnentwig
(@mnentwig)
RE: ASA Help.....
Have you turned off the print fan? I noticed the front right corner is worst and back left best. So draft still seems to play a role. I'd try e.g. painters' tape to tighten all the cracks, at least for a trial.
Napsal : 09/06/2026 1:47 pm
RE: ASA Help.....
Posted by: @steve-s-3
Vent is Close
Will need a lot more information than that otherwise can only throw wild guesses at you.
  1. What bed type, adhesive and nozzle are you using?
  2. Can you attach the zipped 3MF project file?
  3. If not, can you supply some images and print settings?
  4. As for the print settings: nozzle, bed and chamber temps, # walls, infill and percentage?
  5. What have you tried so far?
Napsal : 09/06/2026 1:48 pm
