ASA Help.....
OK we have 6 Prusa Printers. We have an ASA print that prints great on both of our XL Printers, but warps everytime after 50% has been printed on the core one L.
We use the same filament across all printers - Polylite ASA
Vent is Close
Open to suggestions.....
RE: ASA Help.....
Have you turned off the print fan? I noticed the front right corner is worst and back left best. So draft still seems to play a role. I'd try e.g. painters' tape to tighten all the cracks, at least for a trial.
RE: ASA Help.....
Vent is CloseOpen to suggestions.....
Will need a lot more information than that otherwise can only throw wild guesses at you.
- What bed type, adhesive and nozzle are you using?
- Can you attach the zipped 3MF project file?
- If not, can you supply some images and print settings?
- As for the print settings: nozzle, bed and chamber temps, # walls, infill and percentage?
- What have you tried so far?
