RE: 6.4.0 Firmware for Prusa XL
The check is under Settings>Hardware>G-Code Checks and it has 3 options off, warning, strict
Maybe it is always on now.
It is always on in firmware now. So you need to update your printer profiles in Configuration Assistant to Original Prusa XL-5T Input Shaper, to avoid getting the g-code warning. Or disable the warning as described above but I would suggest updating your 3mf project files with the new printer settings.
Not sure whare to find Configuration ASSISTANT in Slice 2.9.4. I have looked at Configuration Wizard, check for configuration updates and application updates. Everything says that I am up to date.
Looked in the wrong place. Have found it and applied. Had been usinging the Original 5T .4 nozzle before. Thanks.
RE: 6.4.0 Firmware dla Prusa XL
Ciekawe Kiedy PRUSA naprawi/zaktualizuje ten wadliwy "nowy" firmware ???
Same, 100% failure rate at the cleaning step at the start of every print I believe. Probing seems slower as well, but I don't keep a close eye on it. It's super frustrating to have to manually intervene on the cleaning every time.
I'm still having these issues with failure to complete a nozzle cleaning and this annoying "probe the bed a stupid amount of times" issue. How do we turn this off but keep the 6.4.0 firmware? What should be a 30 minute print takes an hour because it insists on probing around each probe point. I have cleaned the nozzle several times and it still goes through this annoying process. This was never an issue before.
I get that an occasional failure can/should happen if the control is solving a problem but this, for me at least, was not a problem before. Whatever was introduced is not working. It has introduced a massive bug into the process.
Also getting the `The G-code isn't fully compatible` on my 5 head XL with 6.4.0 firmware and everything else updated.
If it is needed to switch to the `Prusa XL-5T Input Shaper` profile, it should be communicated upfront... this is so silly...
Also, I wasn't able to ever use the `Prusa XL-5T Input Shaper` profile because calibrating for input shaping always fails... So maybe there should be a better procedure to make that work.
This is pretty unfortunate... I understand Prusa needs to keep selling stuff like the new Core one, but we paid a pretty high price for the XL, and we want to be considered as customers, not let-go...
I opened an issue at https://github.com/prusa3d/Prusa-Firmware-Buddy/issues/5061 for tracking
No trouble at all then this. layer shifts, extruding failures, printer reboots, too cold to heat heater. I had to roll back. No trouble again.
Yes, that's right. Since downgrading to 6.2.6 and numerous print jobs, there have been no errors, crashes, or other incidents.
Phase stepping is completely broken in this version in my case. Instead of reducing vibrations, the calibration is actually amplifying them. Impossible to stay in the same room with the printer. Same gcode with 6.2.6 is dead silent.
I had a bad screaming noise coming out of my toolheads, that gradually built up after going to 6.4.0, I ended up replacing all the rails and pulleys with Prusa support's help. After reading a Reddit post this week, with the same problem as me, I tried downgrading the firmware, and the noise went away.
I had done a full format and recalibrated everything on 6.4.0, didn't help, but after downgrading to 6.2.6, the Prusa is silent again.
This is too bad though, because 6.4.0 did fix a random tool crash issue.
I've attached videos as examples, I'll probably post this on another forum discussion with a similar issue as well. I have no idea why the firmware would cause a rattling/buzzing/screaming noise in the toolheads.
https://photos.app.goo.gl/hUp3ibe88H68aZ8h8
The hubbub about the quality of the 6.4.0 firmware is bad enough that a tech support person from Printed Solid insisted that I revert to 6.2.6 before continuing to diagnose some (possibly filament-related?) issues with intermittent squeaks from my extruder.
This is despite the fact that the bed leveling on my Prusa XL repeatedly fails on 6.2.6 but works fine on 6.4.0. To be fair, if bed leveling only works well for one firmware, that's likely a sign of an underlying hardware problem that one firmware tolerates better than the other.
@james-ramsey, this is funny as I NEVER got any bed levelling issue... except in my last few prints on 6.4.0
before, the head was probing few points here and there, then started to print.
Now, it probe few points, then start probing in square or in circles, then fail...
After rebooting the printer, everything went well...
I guess I'm going to wait for 6.4.1, if that ever comes out...
There is no automated way to revert your firmware version. You just to install an older version
Version 6.2.6 can be found from their GitHub page: https://github.com/prusa3d/Prusa-Firmware-Buddy/releases/tag/v6.2.6
Save to a root of a flash drive
Insert into printer
Reboot printer
Enjoy
Insert into printer
Reboot printer
Enjoy
That's not quite how you downgrade firmware. You've missed a few steps; see here: https://help.prusa3d.com/article/how-to-downgrade-firmware-core-one-mk4-s-mk3-9-s-mk3-5-s-xl_725930
Hello.
Based on your feedback and the reports we’ve received, we’ve decided to withdraw firmware version 6.4.0 for the Original Prusa XL. The main issues are related to Phase Stepping calibration.We are currently working on a fix, which should be available in the coming weeks.
If you are experiencing Phase Stepping issues (noise), layer shifts, or random tool crashes, please downgrade to the latest stable firmware version, 6.2.6.
These issues affect only the Original Prusa XL. If you’re running firmware 6.4.0 on your MK4 or CORE One, there is no need to downgrade.
