"Manual" multicolor
Page 9 / 9
ExtrudingThoughts
(@extrudingthoughts)
RE: "Manual" multicolor
Posted by: @sdhayes
This has been working pretty well for me but I'm still working out some of the little kinks.
Has anyone else seen the "A filament specified in the G code is either not loaded or wrong type" warning immediately after you tell the UI to print? I have PLA loaded in the printer and PLA specified in the slicer so it's not a "real" problem and I have found that simply clicking through the error message results in everything working just fine, so I'm wondering if it's maybe some sort of a recognition issue wrapped up in "faking" the multiple extruder arrangement.
As I said, clicking through it works just fine, I'm just wondering if it's something I have setup incorrectly.
I'm seeing the wrong filament error on a Core One, PETG is loaded and single extruder _PETG_ files have no issue.   The file name when doing manual multi-color contains .._PETG,PETG_.. yet the Wrong Filament error occurs and the second filament, which was PETG was under extruded when I chose to print anyway.
Posted : 20/08/2025 8:01 pm
Studi_Ha
(@studi_ha)
Thank you very much! It works perfectly on my MK3+ with a small cleaning tower L=10mm.
Posted : 30/11/2025 1:06 pm
Studi_Ha
(@studi_ha)
Posted by: @mike_gka
I have done some improvement to the Tool change G-code
; eliminate first tool change
{if previous_extruder != -1}
G0 Z{toolchange_z+10} F6000
M601 ; Pause
M400 ; wait until all moves are completed
; color notification
M117 Next color is { (extruder_colour[next_extruder] == "#00FF00" ? "GREEN"
:(extruder_colour[next_extruder] == "#FF0000" ? "RED"
:(extruder_colour[next_extruder] == "#FFFF00" ? "YELLOW"
:(extruder_colour[next_extruder] == "#0000FF" ? "BLUE"
:(extruder_colour[next_extruder] == "#FFFFFF" ? "WHITE"
:(extruder_colour[next_extruder] == "#000000" ? "BLACK"
:(extruder_colour[next_extruder] == "#999999" ? "GRAY"
:(extruder_colour[next_extruder] == "#D4AF37" ? "GOLD"
:(extruder_colour[next_extruder] == "#C0C0C0" ? "SILVER"
:(extruder_colour[next_extruder] == "#FF8000" ? "ORANGE"
:(extruder_colour[next_extruder] == "#800080" ? "PURPLE"
:(extruder_colour[next_extruder] == "#FF6600" ? "ORANGE"
:(extruder_colour[next_extruder] == "#F0F0F0" ? "TRANSPARENT"
:(extruder_colour[next_extruder] == "#800000" ? "BROWN"
:extruder_colour[next_extruder] ))))))))))))))};
G4 S4 ; wait 4 seconds
M600
{endif}
This will eliminate the M600 when start printing.
And the printer will pause before every tool change and after resume (Click continue) the printer will show the next color on the display for 4 sec.
Posted : 30/11/2025 2:02 pm
Patrick.b
(@patrick-b)
hi , will test on the Core 1 😉
Posted : 30/11/2025 6:16 pm
BIGRED
(@bigred)
Not sure if this has happened to anyone else, after upgrading to 6.4.0 from 6.2.6, my manual multicolour prints are now borked...
The issue, after loading the second colour, there's a slight shift, like 1mm down/left.
I tried the print 3 times, resliced, checked XY alignment, re-run calibrations, utterly cracked the poops...
Thought, a quick roll back might be worth a shot... bingo. Ugh... 🙄
Posted by: @patrick-b
Without autoloading it sounds like a PITA... I mean seriously, having to manually feed filament through a bowden every manual change, yucky.
This won't be an issue soon, I'll be grabbing a Core One L with INDX the second they're released. Can, not, wait.
This post was modified 3 months ago by BIGRED
Posted : 03/12/2025 8:40 am
Studi_Ha
(@studi_ha)
@mike_gka
I've used your code a lot, thanks for that!
One question:
How far could the lines of the color code
:(extruder_color[next_extruder] == “#800000” ? “BROWN”
be extended without compromising functionality?
So not just to basic colors, but to other shades as well?
Greetings from Switzerland
M601 ; Pause
M600
{endif}
Posted : 10/02/2026 12:49 pm
Mike_GKA
(@mike_gka)
@studi_ha
I've never heard of a limit, but honestly, I really don't know.
Posted : 10/02/2026 2:09 pm
Page 9 / 9
