After each power on, new Core One recalibrates home, bangs the Nextruder against the corner and reports a printer collision
I have assembled a Core One myself. Everything went smooth until I powered-off the Core One after belt tuning and initial calibration. (When I do not use my printer, I completely power the printer off the printer via the main switch on the PSU.)
Now, every time when I power on the printer and start the first print the following things happens:
- The printer shows the message "Recalibrating home. Printer may vibrate and be noisier".
- The printer bangs the Nextruder against the front-right corner a dozen times. I understand that this is called "sensor-less homing" and is intentional so that the printer re-calibrates its position after a power-loss. But I read that the printer would at most bang the head against each corner two times, not a dozen times. It really sounds as if the printer is going to break any moment.
- After a couple of minutes the message "A printer collision has been detected. Homing ..."
- The printer goes on with banging the Nextruder
- Eventually, the printer pulls trough, seems to be happy and just prints fine.
What is going on here? I have been really, really carefully during assembly and belt tuning seems fine. When the printer is powered off, I can move the extruder with some but still little force along all axis.
Video with sound: https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/09/261b0a77-pxl_20250922_180023082.ts2_.mp4
RE: After each power on, new Core One recalibrates home, bangs the Nextruder against the corner and reports a printer collision
I'm experiencing what seems like the exact same thing you've described.
It seems like this isn't new, with another thread posted today about it: https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/coreone-printing-head-home-position/
And earlier, this thread has more discussion and is from back in February, I believe: https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/constantly-recalibrating/
At least it pulls through! But yeah, I'll be holding my breath for some sort of fix or acknowledgement from the Prusa team.
Cheers
Hi Matthias, the only time my printer did more banging around was due to the belts being not at the right tension (much like new strings on a guitar, the belts need retuning until they settle on a decently stable config); have you tried returning the belts?
Yes, I did re-calibrate. These are the steps I performed the first and the second time:
- Loosened both belts up to the point where the belt tensioners were barely holding on the screw.
- Tightened the looser of the two belts such that it had the same tension as the tighter one; at this point the belts were both still pretty loose. I could pull each belt out of its middle line by approximately 1.5cm without any resistance and without snapping back.
- Checked that the gantry was square and that there was no gap on either side when I moved the gantry to the front position.
- Tightened both belts equally and simultaneously until they became tight enough to start vibrating when being pulled (so that the Belt Tuner app could recognize a sound). That was approximately at 60-70Hz.
- Tightened both belts simultaneously and equally until they were both at the average between 92Hz and 98Hz, i.e. 95Hz
- Then loosened the lower belt and tightened the upper belt simultaneously by the same amount until they reached 92Hz and 98Hz, resp.
All the time I constantly checked that the gantry did not come out of alignment. Did I also mentioned that I checked the perpendicularity of the mounting brackets of the gantry with a machinest gauge during assembly, because I read in the comments that those brackets are known to be skew?
I also printed the Vernier Skew Test. Intrerestingly, it showed a negative skewness of -0.5mm with the belts being at 98Hz (upper belt) and 92Hz (lower belt). I had to go back to 96Hz and and 94Hz to get a zero.
But either way it didn't make much of a difference.
Each time, the first auto homing (i.e. directly after th belt calibration) worked nicely: only two bangs and homing was finished. I thought, yeah, that was it. But after the first or second print the homing procedure was running forever again.
I could understand that the belts of a newly built Core One need to settle in, because nee belts might give in after some time and needed re-calibration. But that shouldn't happen after a single print. Also I could not measure any deviation in the frequencies when it started to happen again. Interestingly, homing sometimes (but rarely, maybe 1 out of 10 times) suceeds instantly.
That is totally annoying.
One thing to try perhaps is the 6.4.0-rc firmware release where there have been improvements made to homing. I've been running it for a few days. There are bugs but they are minor. The new belt tuning strobe is cool. Can always restore to the previous firmware if it doesn't work out.
I am not prusa support but I'd look at a couple of things at this point (and please pardon me if you did already):
- cable of the sensor behind the handle not interfering in any way with the gentry movement
- top cable and ptfe tube not allowing enough movement of the head
beyond that I think I'd use support...
I am not sure to which cable you specifically refer to in your first bullet point (which handle? which sensor? etc.), but Gantry movement is fine. There is not a single cable or PTFE tube which interferes. I am used to be a very nitpicking craftsman, so I am sure that there is nothing wrong with the assembly. At least nothing with the more obvious aspects about which plenty has written in this forum and the comments below the assembly instructions (belt tension, alignment of gantry, obstacles from cables and tubes).
However, reading all the post in the other thread, I believe it might be related to chamber temperature (see my post in Re: Constantly recalibrating). I hadn't made the connection until I read about that aspect in the other thread, but it could be the reason indeed as it would be in line with my observation. Each time after a repeated calibration, the very first homing run smoothly. But it became worse after each single print (not within weeks, but hours). See my text
I could understand that the belts of a newly built Core One need to settle in, because new belts might give in after some time and needed re-calibration. But that shouldn't happen after a single print. Also I could not measure any deviation in the frequencies when it started to happen again. Interestingly, homing sometimes (but rarely, maybe 1 out of 10 times) succeeds instantly.
Obviously, after a repeated calibration the chamber was cold and I print mostly high-temperature material such as PC. My chamber temperature is usually between 55° and 60°C. So a temperature related problem might be indeed the reason. I will give it some observations and then probably contact Prusa support. However, one should assume that Prusa had tested those scenarios.
A reboot of the printer helped me out in this case. It looks like a firmware issue for me.
Been having this for a while now. When it starts banging too much sometimes I get frustrated and restart the printer - after a restart it seems to get over the banging phase much smoother. And yes, belts calibrated and gantry checked etc
What I do now is just add the 'I' in the the Start G-Code in PrusaSlicer:
G28 I ; home all without mesh bed level
This skips the head banging. If you have regular power cuts I wouldn't recommend it as the print won't continue from its last point accurately, but considering I rarely have power cuts and I'm not production printing I don't really care. In fact, at times I have used Bambu printer instead because I can't be fussed listening to all that banging again!
And of course the standard question: did you the check the correct orientation of the x and y motor pulleys. X > tooth up. Y > tooth down
https://help.prusa3d.com/guide/5-corexy-assembly_835522#843284
PS:
your step6 should not be neccessary and puts the gantry off square.
The difference in frequencies is only because of the different legth of the two parts of the belts in front of the linear rail.
............6 Then loosened the lower belt and tightened the upper belt simultaneously by the same amount until they reached 92Hz and 98Hz, resp.
Had similar issues. Once watched the printer humping and banging as if possessed for 5 minutes. Then made the following observation:
Z-height was 165 or thereabouts but this was not the height Prusa link reported. So I moved the Z-axis to a height of approximately 30mm and guess what, ato hominy and recalibration was over in a few seconds. Need to observe more closely.
Interesting how under the same conditions two machines behave differently. I also print almost exclusively PCBlend but so far no strange head banging. It would be interesting to see the output of the serial line when the machine boots into banging mode and compare to a normal behaviour...
I was printing heat towers for various filaments and it actually happened when changing the filament. So not during booting.
I also think one would even need to take it a step further i.e. looking what type of measurements are providing the input to the firmware. Current of the stepper motors, or load cell or else? Temperature also might have an influence. When I started in engineering in the late seventies of last century we had opto-couplers which did not work between 54.5 and 55.5 degreesC perfectly worked below and above those temperatures. 🤔. Yep, would be really interesting to find out maybe during the next rainy season - but spring has just begun here in Australia.
The only times I've had excessive head bangs were under two case: the belts were too loose and the gantry was no longer square. Now that I have them both under control I get normal movement when homing.
As already pointed out by someone else, pass the calibration tests with flying colours but then sometimes this annoying long recalibration starts. And after all, why would the printer detect a crash if the Z-height is 165mm??
Would anyone know, wat is measured during homing and how it is measured? That could give us a clue where the problem might be. Also what is done with the measurements after calibration is finished.
I mean with the mesh bed levelling the firmware produces some correction values for the Z-height but what and how are the X/Y calibration values used?
Have you found a solution to this? I just got my Prusa Core One and the first 3 prints it had no issues at all, but now it has the same issues. Weird homing behaviour and constantly detecting "crashes". I don't get what exactly it is measuring that counts as a "crash", so I have no clue how to solve this problem/what to check for.
Run the manual belt tension wizard. Probably either the belts are too loose or the gantry is bent.
After having upgraded to 6.4.0 there is no problem anymore. Non of the previously experienced issues occured again. so my suggestion would be to upgrade to 6.4.0 first and if problem persists then to redo the belts
