SideKick, the Prusa XL Filament Loader (from the Bowden Speed Loader guy!)
Pagina 1 / 2
MrFlippant
(@mrflippant)
Although I did have a lot of requests for this, it wasn't until I came up with a way to have one motor, battery, switch, and gear for all three filaments, on the side of the XL, in a way that will fit on the side, that I decided to start working on it. I also wanted to use as many of the same parts from the Bowden Speed Loader as possible. Unfortunately, there are still many new parts to get.
The design goals for this project changed over time, but my main priority was to avoid having to change the OEM hardware in any significant way. This also included being able to install and remove it without dismantling, even unplugging, the filament sensors. Since it was to be battery powered, the battery needed to be easy to change in situ. It also had to be securely mounted to the frame of the XL. I was able to keep the GA12-N20 gearmotor, but also designed a version for a motor with a bit more speed and torque.
To use, simply insert the filament through the filament sensor and ensure that it goes into the gears of the SideKick. Press the paddle that aligns with the filament you just loaded. There is no need to fold the other paddles back, but if you prefer to do so, they will fold all the way back and out of the way. As long as you don't apply pressure to the other paddles, all will be well.
https://www.printables.com/model/1576747-sidekick-the-prusa-xl-filament-loader
Postato : 06/03/2026 5:28 am
2 persone hanno apprezzato
MrFlippant
(@mrflippant)
RE: SideKick, the Prusa XL Filament Loader (from the Bowden Speed Loader guy!)
Not gonna lie... The SideKick with external power is way better than batteries. 😉 I had an old tablet PSU that was no longer useful (tablet died) that had about 11V output and a few amps to play with, so I cut off the connector and soldered up some wire and 9v clips to connect it up to my two SideKicks. Just like my test with a bench PSU a while ago, it cooks and barely slows down. Sure, the 9V did the job, and is easy, but if you can dig up an old psu of some kind, or are bold enough to connect it to the XL PSU, then I can't argue against it, so long as you know what you're doing. Even after testing the polarity of everything, I still ended up having the SideKicks run in reverse. That's what I get for soldering and shrink wrapping before actually testing. LOL
Postato : 16/03/2026 5:22 pm
1 persone hanno apprezzato
MrFlippant
(@mrflippant)
Excellent news! Blurolls has made a complete hardware kit for the SideKick! I'll post a link on the Printables page as well as in the OP, but if sourcing the hardware was slowing you down, you can't use that excuse anymore! 🙂
https://www.blurolls3d.com/products/sidekick-prusa-xl-filament-loader-designed-by-mrflippant
Postato : 17/03/2026 5:26 pm
MrFlippant
(@mrflippant)
Another SideKick remix, this one with an even beefier motor for the direct drive version. Check out the demonstration video, too!
https://www.printables.com/model/1645171
Postato : 21/03/2026 4:02 pm
dmbgo
(@dmbgo)
I have just ordered 2 of the the sidekick kits from Blurolls. I noticed afterwards that they have 12v motors. It would be easier to use a rack-mount 24V Meanwell psu, that I already have....
Postato : 23/03/2026 11:10 pm
MrFlippant
(@mrflippant)
Posted by: @dmbgo
24v motors are not terribly common. Ideally, you should use a step down converter from the 24v to the 12v. The Option 2 on Blurolls has such a converter.
Postato : 23/03/2026 11:18 pm
dmbgo
(@dmbgo)
Postato : 23/03/2026 11:36 pm
dmbgo
(@dmbgo)
🙂 I have 4 geared 24v motors that I bought on Ali, when I started building a similar device to yours, but mine was still in the prototype phase. Rather than modifying mine, I thought it would be easier to build yours. https://www.aliexpress.com/item/1005009160858211.html?spm=a2g0o.order_list.order_list_main.5.3cf31802GyNWNI
Postato : 23/03/2026 11:37 pm
MrFlippant
(@mrflippant)
Posted by: @dmbgo
That link stops at 12v, but maybe you got something else. Is it an N20 or N30? Either way, the important thing is less the motor voltage than the RPM at whatever voltage it's rated for. Those little gearmotors are ok, but quickly lose torque at higher RPM. I tried a 12v 1krpm, but it was only fast for a few inches and couldn't finish loading unless the filament was perfectly straight. 500rpm @12v works much better. If yours is 1000rpm @24v, then that's the same as 500@12v, and might work ok, though 24v might reduce the lifetime of the motor.
The one for the direct drive SideKick, as sold on Blurolls, is WAY better than the little one you pictured above. Those are OK for the Bowden Speed Loader, and will work in the Compact Drive SideKick, but again, it needs to have the right gear reduction so that it doesn't lose torque before loading is complete. I ho0nestly don't recommend them, and only included that option for people that had most of the parts already. You could remix the design and use the N20 gearmotor as a direct drive, eliminating the need for the two gears required in the compact drive version. That additional 2:1 reduction might be needed if your gearmotor is high rpm, though. If you still have the package or can access the original order, I'm curious to know what the rpm is for whatever voltage it says.
Postato : 23/03/2026 11:47 pm
dmbgo
(@dmbgo)
I had to turn some bushings to make the extruder gears that I had fit these motors.
Postato : 23/03/2026 11:51 pm
MrFlippant
(@mrflippant)
That gear isn't really used in the SideKick. If it is, you'll need a different spur gear in the compact drive design.
Good for the Bowden Speed Loader, though.
Postato : 23/03/2026 11:55 pm
dmbgo
(@dmbgo)
It was an N30 motor. Maybe I was mistaken and it was 12V?
Postato : 23/03/2026 11:57 pm
dmbgo
(@dmbgo)
I think, it's going to be best to wait for the Blurolls kit of parts, and then deal with the voltage. I can make a voltage divider for my 24v supply.
Postato : 24/03/2026 12:00 am
MrFlippant
(@mrflippant)
Posted by: @dmbgo
Sounds like a good idea.
Postato : 24/03/2026 2:45 pm
MrFlippant
(@mrflippant)
Posted by: @dmbgo
You get your kit yet? 🙂
Postato : 19/04/2026 3:55 am
dmbgo
(@dmbgo)
Yes, it arrived last week, it's sitting on my desk. I'll assemble it tomorrow.
Postato : 19/04/2026 11:50 am
mnentwig
(@mnentwig)
Just a thought, this could be an interesting microcontroller project e.g. Raspberry Pico:
- step-up converter from battery to e.g. 24 V
- current sense resistor / ADC
- some FET with PDM from the µC
and drive the motor with constant or limited current (=> stepper drivers). Otherwise it is able to draw very high current even from low voltage (= torque) when stationary, but it goes down quickly when it picks up speed. Essentially, the rotation causes it to act as a generator, with the voltage in opposite direction to what is applied externally. And at idle speed, the two voltages are matched (minus losses) so it can't have any torque left to accelerate further or do any work.
Postato : 19/04/2026 1:27 pm
MrFlippant
(@mrflippant)
Posted by: @mnentwig
Adding some smarts would be cool, but it would also require additional mechanical components to engage and disengage the filament clamping force while loading, but not add resistance while it's idle during printing.
I encourage people to take my concept and improve on it or come up with something entirely new that's better in some/every way, though.
Postato : 19/04/2026 3:23 pm
MrFlippant
(@mrflippant)
I'd appreciate some feedback on how I can get more eyes on my SideKick filament loader without being all spammy about it? I've recently changed the photo and added a little descriptive blurb about it at the beginning of the description, but I'm having trouble coming up with ways to improve the first impression, so that people who see it at least look into it rather than skip it without understanding how useful it can be.
Postato : 23/04/2026 9:14 pm
dmbgo
(@dmbgo)
I will leave feedback, when I have assembled it. ATM, it's still sitting on my desk. Today perhaps? Sorry - I can see you're keen to get some testimonials 🙂
Postato : 23/04/2026 9:38 pm
Pagina 1 / 2
