Prusa XL Enclosure - PSU
Seth
 Seth
(@seth-2)
The XL PSUs are stuck behind the printer.  Is this going to be an issue if the printer is completely inside an enclosure?
Veröffentlicht : 28/10/2023 10:20 pm
MME
 MME
(@mme)
RE: Prusa XL Enclosure - PSU
That was one of my concerns. I opted to build the enclosure on the framework of the printer. That left most of the electronics out of the enclosure.
Veröffentlicht : 28/10/2023 10:49 pm
Seth
 Seth
(@seth-2)
Are you concerned that the steel side panels are going to be conducting heat out?
Posted by: @mme
Veröffentlicht : 28/10/2023 11:14 pm
MME
 MME
(@mme)
Not for what I am printing. Printing ASA the enclosure is holding at 45C. That is with leaving the upper back vented area open. I haven't decided how to treat that area of the printer. You could make some thin foam or a reflective material panel for those areas. I haven't felt the need to insulate any areas right now.
Veröffentlicht : 28/10/2023 11:39 pm
Seth
 Seth
(@seth-2)
What about if you print a curtain made from TPU that hangs from the back panel and allows the cables and tubes to pass through?
Veröffentlicht : 28/10/2023 11:49 pm
MME
 MME
(@mme)
I don't think you would have to cover the entire back. You can take a look at the enclosure here.
https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-user-mods-octoprint-enclosures-nozzles/ideas-to-make-enclosure-for-xl-multi-tool/paged/9/#post-681246
Veröffentlicht : 28/10/2023 11:55 pm
Seth
 Seth
(@seth-2)
I have been following your build and looking forward to the final product and details.
For me simply buying a sheet to enclose the whole printer will be easiest except for the PSU and electronics issue.
A full also enclosure allows me more freedom in the design for heating and circulation since there is space.
Veröffentlicht : 29/10/2023 12:01 am
Peter Wham Bam
(@peter-wham-bam)
Mitglied
does anyone know where to find cad designs for the XL?
thanks
Veröffentlicht : 05/12/2023 9:20 pm
bithead007
(@bithead007-2)
I'm going down this road I ordered the acrylic, and the parts have been printed in nylonX and all the hardware is here. Might have some results on January 27. https://cults3d.com/en/3d-model/tool/prusa-xl-enclosure-custom-jussin5150/comments
CJ
Veröffentlicht : 12/01/2024 12:00 am
polimr
(@polimr)
I had the same concerns as I've also fully enclosed my XL.  I tried tracking down more information on the Delta PSUs but I couldn't even find them listed on the website let alone a recommended operating temperature range.  Asked a friend who works in and on data processing centers; told him I'd be running the enclosure  at <90F and he said it shouldn't be any kind of problem and not to worry about it.  Although he did add that he thought the thermal weak point was the LCD, so I'm working on getting that part outside.  I originally thought the LCD position on the XL design was just an accident waiting to happen but since Prusa is parking the LCD so far out of the machine maybe I should get it out of the enclosure too.
Posted by: @seth-2
Veröffentlicht : 07/03/2024 10:16 pm
