Is there or will there be a unified semi-assembled plus enclosure instruction set?
araspitfire
(@araspitfire)
As the title says.. I ordered the combo (thus adding some weeks to delivery)
I was looking over the instructions for the enclosure (and previously looked over the semi assembled instructions)
It seems that an instruction set that adds enclosure steps into the Semi assembled instruction train in an appropriate place would be a time saver.
Publié : 23/07/2024 5:19 pm
Cotano
(@cotano)
RE: Is there or will there be a unified semi-assembled plus enclosure instruction set?
I’m in the same boat. My thought was to read them both and make changes as required. Biggest thing we would lose from a new manual is the comments.
 But knowing Prusa they are already designing this.
Publié : 24/07/2024 7:42 am
luma
 luma
(@luma)
Membre
Apart from a couple cables that need to be re-run, there is very little re-work when assembling and installing an XL enclosure.  I have a launch day printer so I had a bunch of printed parts to replace with PCCF equivalents that took a while on a five tool printer, but for a new XL that won’t be a problem.
I don’t think you’ll find yourself too fussed by simply assembling the XL and then diving into the enclosure build.
Publié : 30/07/2024 10:45 pm
2 personnes ont aimé
Kurt Gluck
(@kurt-gluck)
You should all feel the pain and the glory of starting with 0.6mm nozzles and all sorts of PETG that you have to replace that some of us have in store.   To be fair, I started with the Semi "Assembled" 5TH one.
Also a 2 year wait is good for the soul 🙂
You are going to love your printer
Publié : 02/08/2024 2:17 pm
Cotano
(@cotano)
I purchased the 0.6 nozzles because I wanted them.  Never had an issue with that size.  Granted you have to change your settings to match it.
In addition I’m also planning on replacing the tensioners with Asa.  I’m hearing issues  are occurring with the petg versions.
Posted by: @kurt-gluck
Publié : 02/08/2024 7:53 pm
