Height Difference Between Extruders
I've swapped out Extruder 1 for a 0.6mm hardened nozzle with the V6 adapter. Extruder 2 still has the Prusa 0.6mm brass nozzle. I'm finding that when I use both nozzles, Extruder 2 prints about 1mm too high off the bed. I've lowered the z height during a print, but this affects both extruders. Is there a way to set the height difference between the two nozzles?
Postato : 22/12/2023 1:52 am
Main menu -> Control -> Calibrations & tests -> Tool offset calibration
Questo post è stato modificato 2 years fa da Jaakko
Postato : 22/12/2023 2:04 pm
