XL - MK3s Fiberthree F3 PA-CF Pro comparison
Revel
(@revel)
I printed Fiberthree F3 PA-CF Pro on both my MK3S and my XL with the same spool.
I dried it out and then printed benchy on the MK3S then XL back to back. Not sure if the filament could absorb water in that time for a worse print on XL.
You can see in the image the difference in quality and accuracy. I used stock settings other than making sure a .2 quality and 15% gyroid were the same.
I'm curious about thoughts on this.  Is what I'm seeing here largely because of the .4 vs .6 nozzle difference and if I installed a .4 on the XL I could see the same quality or better?
I also attached an image of a larger print on the XL (ran directly out of the dryer) where you can see a very sandy uneven layering.
CLICK IMAGE TO SEE DETAILS
Veröffentlicht : 31/01/2025 4:54 pm
Alexandre O
(@alexandre-o)
Mitglied
what type of bed sheet did you use ?
nylon bedsheet are nowhere to be find.. do you think i can use smooth with kores ?
I am open to any idea
thanks
Diese r Beitrag wurde geändert Vor 1 year von Alexandre O
Veröffentlicht : 05/03/2025 12:49 pm
