XL Cannot print this... or can it?
Chris
(@chris-44)
I have been trying in vane to print the lid of this model
https://www.printables.com/model/545197-prusa-tools-rugged-boxes-parametric/comments
What ever I try I keep getting this error. This should be straight forward, but not so.
Can someone give it a try?
Napsal : 29/09/2023 3:57 pm
Acht
 Acht
(@acht)
RE: XL Cannot print this... or can it?
I already printed it. Have you sliced it your self for your specific printer?
What printer do you have? Can you upload your gcode?
Napsal : 30/09/2023 9:50 am
Chris
(@chris-44)
I don't know what I'm doing wrong in the config. The printer is a dual head XL. I have attached a link to the model.
3mf file
Napsal : 30/09/2023 4:43 pm
Hello
(@hello)
Posted by: @chris-59
3mf file
Seems like the printer thinks it's a single head
Napsal : 30/09/2023 7:03 pm
Chris
(@chris-44)
Yes, you are correct.
Even tried to set the printer as an XL with single extruder. Same error!
Napsal : 30/09/2023 7:15 pm
Chris
(@chris-44)
Acht;
Could you attach your setup file for the XL for this print. Still struggling to print this.
Napsal : 05/10/2023 7:47 pm
DANGT4
(@dangt4)
In the 3mf it shows there are 4 colours being used so 4 toolheads.  Thats probably why its not working as yours is only a dual head.
If you slice it you can see that it thinks its using black, white, grey and red.
This post was modified před 3 years by Etrimon
Napsal : 08/10/2023 1:01 pm
DANGT4
(@dangt4)
And apologies for the weird effect where the attached photo is floating at the top of the page.  I've sent prusa a report about this and on another of my posts.
Napsal : 08/10/2023 1:10 pm
Acht
 Acht
(@acht)
Hey sorry,
missed your post. I don't have the original File anymore, but as already sad, as you have the two toolhead Version you can only use 2 toolheads. I attached how I would slice it, but depends on the exact PLA and so on.
Acht;
Napsal : 08/10/2023 2:16 pm
Chris
(@chris-44)
The author printed this with a single extruder on his MK4. I have tried to set the XL to single extruder, same error. Using the "single extruder multi material" does not seem to work on the XL.
Basically how do you print 3 colors on the same layer with 2 extruders. If I could figure this out, I could solve the problem. I have submitted a ticket to PRUSA on this issue, with so successful resolution. It shouldn't be this complicated.
Napsal : 08/10/2023 2:22 pm
Acht
 Acht
(@acht)
Attaching didn't work and I cant edit my Post somehow, but here is the FIle:
https://drive.google.com/file/d/10CQY5Zm-KDrbNvxIGIS_wObQyrP1wRYp/view?usp=sharing
Napsal : 08/10/2023 2:23 pm
Chris
(@chris-44)
Thanks very much. Will give it a try today.
Napsal : 08/10/2023 2:45 pm
1 lidem se líbí
I can't test until my XL arrrives but there is provision in Prusa Slicer.
First set the number of (virtual) extruders required then select 'Single extruder multi material' - you may have to edit some of the 'Single extruder MM setup values' (in Printer > General) and perhaps tweak the gcode as in:
https://forum.prusa3d.com/forum/prusaslicer/manual-multicolor/
https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/acting-as-my-own-mmu
Napsal : 09/10/2023 3:10 am
Chris
(@chris-44)
Done both of these things same error. If anyone has printed this in 3 colors with a single extruder XL, I would be very interested. Seem to be a flaw in the printer firmware.
Last comment from Prusa
"Hello,we are sorry. We will have to check with the developers. There might be a problem between Prusaslicer and printer firmware. I will update you as soon as I know moreBest Regards / S pozdravem—Jakub KučeraCustomer Support"
Napsal : 09/10/2023 4:15 pm
