What could be causing this?
Greg Stone
(@greg-stone)
Membre
Any ideas what could be causing this?
Printer is only a month old, first few prints no issues, then this sort of thing started to happen.  Doesn't happen all the time either.  I re-calibrate both heads pick-up, lubed the rails.  Every time it does happen, its generally at the same elevation.
Publié : 12/12/2024 1:43 pm
Pe3d
 Pe3d
(@pe3d)
Belt tension
Alignment of the frame
Grub screws
Too much cooling
Too much Speed
Wet Filament
...... And a lot more
Try the belts and the Homing Tower at first
Ce message a été modifié il y a 1 year par Pe3d
Publié : 15/01/2025 3:33 pm
Brian
(@brian-12)
RE: What could be causing this?
Probably part warping causing a crash.
Publié : 15/01/2025 4:33 pm
Files > Save Project as
Publié : 15/01/2025 8:07 pm
1 personnes ont aimé
