What could be causing this?
Any ideas what could be causing this?
Printer is only a month old, first few prints no issues, then this sort of thing started to happen. Doesn't happen all the time either. I re-calibrate both heads pick-up, lubed the rails. Every time it does happen, its generally at the same elevation.
Posted : 12/12/2024 1:43 pm
Belt tension
Alignment of the frame
Grub screws
Too much cooling
Too much Speed
Wet Filament
...... And a lot more
Try the belts and the Homing Tower at first
This post was modified 12 months ago by Pe3d
Posted : 15/01/2025 3:33 pm
RE: What could be causing this?
Probably part warping causing a crash.
Posted : 15/01/2025 4:33 pm
Files > Save Project as
Posted : 15/01/2025 8:07 pm
