Success: Fiberlogy Fiberflex 30D - no stringing 🙂
Did various Filaflex Shore 30D tests today. Finally I found some clean values w/o stringing.
I'm using 0.6 hardened steel nozzles from Brozzl, in combination with the nextruder adapter.
Filament settings:
[filament:Fiberlogy FiberFlex 30D @XL 0.6 220°C 4mmRl-30mmRS] bed_temperature = 55 bridge_fan_speed = 75 compatible_printers = compatible_printers_condition = printer_model=~/.*XL.*/ and nozzle_diameter[0]==0.6 compatible_prints = compatible_prints_condition = cooling = 1 disable_fan_first_layers = 5 enable_dynamic_fan_speeds = 0 end_filament_gcode = "; Filament-specific end gcode" extrusion_multiplier = 1.1 fan_always_on = 1 fan_below_layer_time = 100 filament_colour = #008000 filament_cooling_final_speed = 3.4 filament_cooling_initial_speed = 2.2 filament_cooling_moves = 4 filament_cost = 39.41 filament_density = 1.07 filament_deretract_speed = 20 filament_diameter = 1.75 filament_load_time = 0 filament_loading_speed = 28 filament_loading_speed_start = 3 filament_max_volumetric_speed = 5 filament_minimal_purge_on_wipe_tower = 35 filament_multitool_ramming = 0 filament_multitool_ramming_flow = 5 filament_multitool_ramming_volume = 40 filament_notes = "" filament_ramming_parameters = "120 100 6.6 6.8 7.2 7.6 7.9 8.2 8.7 9.4 9.9 10.0| 0.05 6.6 0.45 6.8 0.95 7.8 1.45 8.3 1.95 9.7 2.45 10 2.95 7.6 3.45 7.6 3.95 7.6 4.45 7.6 4.95 7.6" filament_retract_before_travel = 2 filament_retract_before_wipe = nil filament_retract_layer_change = nil filament_retract_length = 3 filament_retract_length_toolchange = 3 filament_retract_lift = 0 filament_retract_lift_above = nil filament_retract_lift_below = nil filament_retract_restart_extra = nil filament_retract_restart_extra_toolchange = nil filament_retract_speed = 60 filament_settings_id = "" filament_soluble = 0 filament_spool_weight = 330 filament_toolchange_delay = 0 filament_travel_lift_before_obstacle = nil filament_travel_max_lift = 1.5 filament_travel_ramping_lift = 1 filament_travel_slope = 1 filament_type = FLEX filament_unload_time = 0 filament_unloading_speed = 90 filament_unloading_speed_start = 100 filament_vendor = Fiberlogy filament_wipe = 0 first_layer_bed_temperature = 55 first_layer_temperature = 220 full_fan_speed_layer = 5 idle_temperature = 70 inherits = Fiberlogy FiberFlex 30D @XL 0.6 max_fan_speed = 60 min_fan_speed = 25 min_print_speed = 15 overhang_fan_speed_0 = 0 overhang_fan_speed_1 = 0 overhang_fan_speed_2 = 0 overhang_fan_speed_3 = 0 slowdown_below_layer_time = 15 start_filament_gcode = "M900 K0 ; Filament gcode\n\nM142 S36 ; set heatbreak target temp" temperature = 220
Postato : 18/11/2023 7:14 pm
2 persone hanno apprezzato
