Solid Layer between each color
Mr Glloq
(@mr-glloq)
A quick question, In PrusaSlicer, how do I make a solid layer between each color change on simple parts.
Regards
Postato : 29/10/2024 10:01 am
What are you trying to do?
Postato : 29/10/2024 12:02 pm
Mr Glloq
(@mr-glloq)
RE: Solid Layer between each color
I try the layers between materials
And at this time, I can't print PLA on TPU
PLA on PETG Ok
PLA on PLA Ok
TPU on PETG Ok
TPU on PLA Ok
But PLA on TPU doesn't even stick and so I was wondering about the filling part, I wanted to test on a solid layer.
I'm looking for the right couples and in which direction.
Regards
Postato : 29/10/2024 2:42 pm
BaconFase
(@baconfase)
Tick on "Interface shells" in Print Settings>Multiple Extruders to get the solid layers between extruders. But it only works if you create the distinctions via multiple parts, used painter-tool, or used modifiers. The setting doesn't seem to work if you're doing your extruder changes via zheights in the sliced preview.
Postato : 31/10/2024 4:30 am
Brian
(@brian-12)
You could also use modifiers to do this if you aren't able to make separate parts.
You could also cut the part in PS using the cut command to break it into parts.
Postato : 31/10/2024 5:38 pm
Mr Glloq
(@mr-glloq)
Ok thanks, I'll test this when the printer has finished its jobs.
Regards
Postato : 31/10/2024 5:44 pm
