RE: Small print removed from slice
As this is a multicolor print did you perhaps inadvertently forget to change the color for those periods in the extruder selection? I ask only because I forgot once to select the "closed" space in a letter A once and the letter ended up filled instead :).
Regards,
Steve
Napsal : 26/11/2025 2:36 pm
