Sequential Printing fails after first part
dominik_koerling
(@dominik_koerling)
Hi there,
I tried to run a sequential printing process of a part in multiple times.
After the first part is completed the print head moves to his new location (X/Y) where he should start to lower (z) for the next part. But then the Display shows a restart and then a „MINTEMP“ error occurs.
any idea?
Napsal : 04/10/2024 9:20 pm
pincoPallino
(@pincopallino)
RE: Sequential Printing fails after first part
Hi, i don't know the exact answer but i'm having the same problem, that is basically caused by the cooling fan being at 100% when starting the new object. So i figured it out this way: turn on the fan after the first layer and set it to 70% max of its power. The temperature will oscillate anyways but not that much to cause the PID error. Let me know if you have found any other solutions 🙂
Hoping to hear from anyone more expert, i have not found any other topics online about this problem
Napsal : 25/11/2024 10:34 pm
