Prusament PC Blend Carbon suport material
Sverker
(@sverker-2)
I will be printng a part that must have supports.   What material should I use as support material.  Using PC blend will make it hard to remove and costly.
This topic was modified 2 years temu by Sverker
Opublikowany : 20/11/2023 10:56 pm
GuyH
 GuyH
(@guyh)
RE: Prusament PC Blend Carbon suport material
I can only comment with limited experience so hopefully someone with more knowledge will come and help. I’ve printed with PC on the Bambu X1C using their support interface material to aid separation. They call it support G but I think it’s just a nylon. So maybe Nylon interface layers is the way to go
Opublikowany : 20/11/2023 11:55 pm
DanOelke
(@danoelke)
I am about to print some bigger parts using prusament PC-CF and was thinking about supports of something else.
Anyone actually try it yet?  Would PLA just be to different in temperature? What about PETG?
Opublikowany : 22/12/2023 2:06 pm
